- Thank you received: 3
Where is the best place to buy carb rebuild kits?
- 300kph
The seats are still available from Kawasaki but they are $62 EACH!
I've seen kits with bowl gaskets, needles, seats and o-rings for as little as $20 per kit.
Don't want junk but a guy like WiredGeorge carbs will do a complete rebuild for about $379.
My number 4 is puking gas and plugs are fouling across the board. Spark is very good as did a regulator to coil mod that give the coils batter power and the spark is awesome. Carbs need work more work though.
Bike runs awesome for about 20 miles on new plugs and then gets rough. Does not idle well, bogs off the line etc. You know, the good stuff!
Put in new needles but the problems persist.
Also, does anyone have a downloaded file or website to a a shop manual rebuild guide for that year of Kawi.
I think the Z1R is different due to the 4 into 1 pipe.
Any help would be appreciated.
W
1978 KZ1000 D1 (Z1R)
1979 KZ1000 A3 (MKII)
1979 Honda CBX (Candy Glory Red)
1980 Suzuki GS1100E (Silver)
1980 Suzuki GS1100E (Red)
1978 Yamaha XS1100
1982 Suzuki GSX1100S (Katana)
1984 Kawasaki KZ1100R (Silver)
2004 Honda Rune (Bloodstone Red)
- wireman
- Thank you received: 299
Attachment seafoam.jpg not found
- 300kph
Not sure why the carbs are being so fussy.
My mechanic is very good at carbs and we cleaned them, synced them and even replaced the needles.
#4 is leaking gas from the drain tube. And as mentioned it fouls badly.
Dealing with the spark issue (added a regulator to deliver battery voltage) and putting on a new breaker plate with new points & condenser and timing it did not cure the problem leaving me to believe the carbs need attention.
We used a clear tube to measure float levels and my guy even weighed the floats to make sure there was no problem.
Found a place here in Canada called Carb Kit Capitol and they seem to have a lot of stuff but never pick up the phone or reply to e-mails. Not a good sign.
Any link to a carb rebuild guide would be appreciated and are my carbs unique to that bike?
W
1978 Yamaha XS1100
- gd4now
- Denco where did you go?
- Thank you received: 445
IIRC the carbs on the 78 Z1R are vm28ss carbs without an accel pump, that are jetted (main, jet needle and needle jet) differently and have a smaller cutaway on the throttle slide than the other models that came stock with the 28s but other than that I am not aware of any other differences between them.
Since one is leaking from the overflow do check the float valve as it may no longer close tight. Would also make sure the overflow tube in the bowl is not cracked or leaking. Since it also fouls badly I would tend to think it is the float valve not closing tight.
Here are some online locations to search for carb parts - would recommend Z1 but that is just me.
www.nrp-carbs.com
www.motorcyclecarbs.com
www.carbparts.com
www.carbkitscapital.com
www.pjmotorsports.com
www.jetsrus.com
www.oldbikebarn.com/Motorcycle_Parts/Carb-Rebuild-Kit
www.cycleorings.com/
www.z1enterprises.com/
www.sudco.com
I am not aware of any rebuild guide for that specific carb - but there is a pretty good write up here www.thegsresources.com/garage/docs/vm_carb_rebuild.pdf
that is based upon vm26ss carbs on a Suzuki. The carbs are very similar to the vm28ss carbs and the write up is full of good pictures and explanations that you may find useful.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- wireman
The sea foam works its way through those tight little ports and scrubs them really good,in line fuel filter probably wouldnt hurt either.
- bugsinmyteeth
- Thank you received: 12
BTW, thorough cleaning of carbs means dissassembly and 24 hr. dip in Berrymans and then making sure all passageways are clean. I believe there is a link to a tutorial on cycleorings site. Also, this was mentioned in a previous post.
When you get it sorted out, please let us know how you fixed it.
Old School Is Cool!
1975 Kawasaki 900 (Z1B)
1982 Suzuki GS750E
Northern KY
- Thank you received: 2098
If not already done, would perform the clear-tube test on each carb to determine whether fuel levels are within specs.
- GregZ
- Thank you received: 88
wireman wrote: Try dumping a big can of this in the tank and running it through first,you might be suprised with results
I don't think I would dump in the whole can :ohmy:
- wireman
Attachment plummen_2012-07-28.jpg not found
Dump in a whole shorter can then and ride wheels off of it,you can always top off the tank after half a tank if youre scurred.
- bountyhunter
- Thank you received: 337
Call Z1 Enterprises and see if they have them.
If not, I have seen them at:
loudfastugly.com
- 300kph
1978 Yamaha XS1100
- gd4now
1977 KZ650 B1
