- Thank you received: 1
Leaking Carb Bowl
- lowkeyfilmz
26 Jul 2012 16:57 #538794
by lowkeyfilmz
Leaking Carb Bowl was created by lowkeyfilmz
Fellow KZ riders thanks for all the posts that have helped me wrench my way off the side of the rode.
I have a leaking overflow nipple on carb 3.
I have checked all the usual suspects, floats, needles, drain plug?
I have swapped known working #1 bowl and float assembly with #3 and still leaky leaky
I have them off and filling from a bottle so I know it's comming out of the nipple.
There is a plastic cap inside that used to fall out so I heated it up and squished it to make a better seal on all the carbs. A little of the brass on the inner assembly is chipped off. (On #1 and #3)
Diaphram is good?
Any ideas?
Diaphram is good?
Any ideas?
- JR
- Thank you received: 449
26 Jul 2012 22:12 - 26 Jul 2012 22:13 #538867
by JR
Replied by JR on topic Leaking Carb Bowl
What bike/engine and what carbs ?
In general there's only maybe 2 things which can cause the leak you describe. One would be a cracked overflow tube but as you swapped with a bowl from another carb and still had the leak then that would seem to rule out the overflow tube.
That just leaves the float needle/valve and seat. I would suggest you take a cotton Q tip soaked in carb cleaner or even Brasso and run it around the seat and realy clean it off.
Examine the float valve/needle tip for ridges and clean.
Or swap the float needle/valve with one from a non leaking carb. Depending on what carbs you have some brass valve seats can also be removed and swapped. Wont fix the problem but should pinpoint the solution
God luck
God luck
Last edit: 26 Jul 2012 22:13 by JR.
- lowkeyfilmz
07 Aug 2012 16:14 #541203
by lowkeyfilmz
Replied by lowkeyfilmz on topic Leaking Carb Bowl
I completely dissasembled and cleaned said carb.
I pushed the needle inthe middle down and up and soaked in seafoam.
Switch out the bowl and whala!
She no longer leaks gas.
I was dangerously close to running the overflow tube on the ground and doing my part to stimulate the turbulent economic climate one gallon at a time!
- lowkeyfilmz
09 Aug 2012 18:32 #541594
by lowkeyfilmz
Put carbs back on and hooked up fuel line and wham fuel everywhere.
I ordered a rebuild kit so we shall go in that direction.
