- Thank you received: 10
Chopping out at high RPM
- Kitten Tooth
24 Jul 2012 09:47 #538158
by Kitten Tooth
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
Chopping out at high RPM was created by Kitten Tooth
Well i just had a really nice rip up the street on that cafe racer my dad has. Just pulled it out of the garage for the second time and got it going again. Put some fresh gas in the tank and drained the older stuff out of the bowls. Started in about 4 kicks and ran kinda crappy for a few seconds that took off on both cylinders and ran like a monster. I put on my helmet and took off up the street. I let the RPMs go up a little bit in first and it started to sputter almost like it was getting flooded or starved of fuel. Then i shifted to second and kept going. Got it all the way to 4th gear with the same problem, it wants to die if you open the throttle to much or get it up to high RPM. I turned around and came back home. In the driveway it revs up fine and doesnt chop out.. Also, the idle speed adjustment screw isnt even touching the plate that opens the butterflies in the carbs and that is the only way to make it idle normal. I checked the intake sides of the carbs to see if there was any gas in there and it was bone dry. Any ideas on whats going on? I gotta get this bike on Craigslist soon so we can free up some space in the garage. Id buy it if i had the money though
Looks sharp as hell :evil:
Thanks guys,
KT
Thanks guys,
KT
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- kawasaki mike
- kawasaki mike
- Thank you received: 4
24 Jul 2012 13:35 #538203
by kawasaki mike
Am addicted to Z1's and kz 900's have an el camino, fly rc helicoptors and am strung out on horsepower.
Replied by kawasaki mike on topic Chopping out at high RPM
Where ever it is crapping out, run it there for a few and kill the engine, pull clutch in and turn of engine. Dont let it turn over after killing it. Pull the plugs and see what color they are. Probably white. So you have a lean symptom at what rpm. Pilot controlls idle to 1000 rpm. Needle position controlld 1000 to 5000 rpm. Main takes over after that.The 3 circuts will bleed to one another by the way.
