Jetting Advice Please :)
- rdhussey
11 Jun 2006 13:08
I've just completed the rebuild of a 1982 KZ750 motroe with stock carbs. I Totally cleaned them inside so they are working optimally.
I installed pods and will have a very open exhaust sysem. I am wondering how I should modify the jets, change the settings, and adjust them.
Any input will be appreciated.
Right now, it idles at 2700 with teh choke on and dies if I apply the throttle or let off the choke at all.
THANKS!!!!
THANKS!!!!
- wiredgeorge
Re: Jetting Advice Please :)
12 Jun 2006 07:31
If they idle at 2700 rpm and won't come off choke, I suspect they may not be working optimally! What kind of carbs would these be? Keihin CV34 or BS34 Mikuni? Do you have the stock airbox on the bike and stock pipes?
- JR
13 Jun 2006 18:02
If your carbs are Keihin CV34s then take a look at the picture below and the bike in my signature which is probably somewhat similar to yours. The pic may point you in the right direction. Stock version of my 135 jet is 125.
I have heard though that these jets can be hard to find.
Good luck
Good luck
