- Thank you received: 1
Pingel Taps
- sled
11 Jul 2012 04:57 #535211
by sled
Pingel Taps was created by sled
Been doing abit of a search on these. I have a standard Kz900 26mm carbs, I find the standard tap which has a double fuel outlet a bi.ch to plumb a inline filter in to both lines. The short one doesnt leave much to play with even with a right angle filter. So was thinking a single outlet Pingel with T connector and no filters. The filters on these things look pretty hardcore. What do you think?
If i was to upgrade carbs and engine later say 1075cc ish and 29mm carbs would single outlet suffice? or should i go double, with / without inline filters.
any advice is greatly appreciated
cheers
cheers
- les holt
- Thank you received: 288
11 Jul 2012 07:30 #535213
by les holt
Replied by les holt on topic Pingel Taps
I run single outlet Pingle on 1075 with 33 smooths, plenty motor work and it hasn't starved for fuel yet. I don't run a filter but the tank is perfect inside also. No problems as of yet.
Les
Les
- Old Man Rock
- Thank you received: 225
11 Jul 2012 08:09 #535217
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Pingel Taps
1015cc with P&P head, .365 cams, 29CR's with an in-line filter using the Pingle single outlet Power-Flo's... More than enough for these hungry girls (Carbies)....
if needed... Pingle
if needed... Pingle
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- sled
06 Aug 2012 22:51 #541107
by sled
Replied by sled on topic Pingel Taps
Thanks for the response
Which model should i order round or hex
BTW both bikes look wicked!
- sled
13 Aug 2012 22:59 #542426
by sled
Thanks for replies
ordered from Z1 can't wait to piss off the pissing tap :laugh:
- gearheadmm
- MUCH MORE BOOST..........I mean BRAVO
- Thank you received: 11
14 Aug 2012 01:30 #542462
by gearheadmm
General Joeseph Dunford FOR PRESIDENT!!!
69.46.28.106/forum/11-projects/413221-80-kz-1000-st-recycled
Replied by gearheadmm on topic Pingel Taps
Pingel's warranty on these is the best in the business!!!
- BlackZ1R
- Kawasaki in my blood
- Thank you received: 47
14 Aug 2012 14:31 #542565
by BlackZ1R
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
Replied by BlackZ1R on topic Pingel Taps
You won't regret it. I have Pingels on 5 of my bikes. No worries. :woohoo:
Kawasaki
