- Thank you received: 1
KZ1000P Needle Jet
- kcornell6
09 Jul 2012 23:26 #534957
by kcornell6
96' KZ1000P Bobbed
81 GS850L
KZ1000P Needle Jet was created by kcornell6
Hey guys,
Hopefully this can be a quick one to solve my problem. I've adjusted needle jets before so I'm not fully in the dark on this one. For my 1996 KZ1000p, I've discovered the needle jets are not adjustable. Am I over looking something some how, or is that just how they were built for some reason?
I need to adjust mine since I've modified the intake and exhaust. (I've rejetted the pilot/mains already).
If I can adjust the needle with washers like many other carbs, that'd be awesome.
Thanks in advance,
Kev
Thanks in advance,
Kev
96' KZ1000P Bobbed
81 GS850L
- Motor Head
- Thank you received: 391
09 Jul 2012 23:30 - 09 Jul 2012 23:31 #534960
by Motor Head
Replied by Motor Head on topic KZ1000P Needle Jet
Yes you can Shim up the needles, same as lowering the clip. You can buy shims or go to a hardware store and have a look. Best to get something that they will all be the same thickness, .020" is 1/2 a clip position I believe.
Last edit: 09 Jul 2012 23:31 by Motor Head.
- gpz1170
- Thank you received: 10
10 Jul 2012 00:02 #534967
by gpz1170
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
Replied by gpz1170 on topic KZ1000P Needle Jet
try Radio Shack, they have an assorted bag of washers for a couple of dollars. that's where I got mine
don
don
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
- kcornell6
13 Jul 2012 19:13 #535726
by kcornell6
96' KZ1000P Bobbed
81 GS850L
Replied by kcornell6 on topic KZ1000P Needle Jet
Does anyone happen to have pictures showing how/where someone put the washers? Not totally understanding where the placement of the washers would go on these carbs since there no clip positions or anything.
V/R
Kev
V/R
Kev
96' KZ1000P Bobbed
81 GS850L
- kcornell6
- Motor Head
29 Jul 2012 19:50 #539440
by Motor Head
Washers/ Shims go inside the slide, on the needle, between the slide and the clip. This shims the needle UP, making more fuel available in the mid range circuit of the carb.
So as you place the needle into the slide, the shim goes on first, spacing up the needle.
- Thank you received: 2098
- kcornell6
29 Jul 2012 21:54 #539471
by kcornell6
96' KZ1000P Bobbed
81 GS850L
Thanks gentlemen. Makes perfect sense now. I don't think I saw the clip to pull out but I'll look again since I'm not around the project right now.
V/R
Kevin
V/R
Kevin
96' KZ1000P Bobbed
81 GS850L
- kcornell6
10 Aug 2012 21:25 - 10 Aug 2012 21:26 #541840
by kcornell6
96' KZ1000P Bobbed
81 GS850L
Hey all,
Now I'm back in state to work on the project I'm sorting out all the carb adjustments. Can anyone explain how to remove this yellow piece with 4 holes in it? I don't want to force anything with snap ring pliers or pushing on anything the way it shouldn't.
Thanks in advance,
Kev
Thanks in advance,
Kev
96' KZ1000P Bobbed
81 GS850L
Last edit: 10 Aug 2012 21:26 by kcornell6.
- kcornell6
- Dragone
12 Aug 2012 19:44 #542153
by Dragone
Replied by Dragone on topic KZ1000P Needle Jet
check out the fiche. Here ya go....
www.powersportsplus.com/parts/search/Kaw...TOR+PARTS/parts.html
Good luck with the adjustments. I have access to a press, so I pressed and mic'd my under needle shims.
- Nebr_Rex
- Thank you received: 300
12 Aug 2012 21:23 #542170
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic KZ1000P Needle Jet
Gently push the needle into the slide.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
