- Thank you received: 1
HOW DO I GET THESE AIR BOOTS ON MY CSR!!!!!!??????
- mjewell
1980 CSR 1000
Cleaned the carbs bike runs descent but I just can't get everything back together. Tried going in from the airbox, tried sliding them in from outside, tried dynamite, tried a case of beer, nothing is working. I really don't want to use pods but they're looking pretty good right now.
Am I going to have to drop the motor and get the whole motor, carbs and airbox together and then put it back in place??
Say it ain't so!
- Nebr_Rex
- Thank you received: 300
Treat them like tire,use a screw driver or small rod bent in an L on the end and walk them around starting on the inside and work out.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- peter1958
- Banned
- Thank you received: 198
- dejavoodo41
- Thank you received: 14
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
- Thank you received: 1656
- wireman
- Thank you received: 299
Attachment AA1.jpg not found
soak em in a zip lock back full of this stuff
- Thank you received: 2098
mjewell wrote:
1980 CSR 1000
Say it ain't so!
If actually a 1981 KZ1000-M1 CSR
www.z1enterprises.com/Airbox-Hoses-4-Kaw...0-81-and-up-411.aspx
- mjewell
- mjewell
- mjewell
- mjewell
- Motor Head
- Thank you received: 391
mjewell wrote: Got new air boots from Z1, went on like butter, I tried everything to get my originals to become pliable. Do yourself a favor and just get new ones.
