- Thank you received: 36
misfire help
- faffi
05 Jul 2012 17:52 #534076
by faffi
If the seat has a metal pan, it can have shorted the main power leads, bypassing any fuses.
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
Replied by faffi on topic misfire help
hiroshima1320 wrote: My first priority is to track down that short. The only thing I can find not working, besides my horn, which hasn't worked since i gpt the bike, is the running lights. The headlight, brake light, and turn signals all work fine...
1977 KZ650B1
1980 F1 engine
B1 Points ignition
- hiroshima1320
- Thank you received: 1
05 Jul 2012 19:08 #534106
by hiroshima1320
Stop dreaming the life. Start living the dream.
Replied by hiroshima1320 on topic misfire help
Ok. Found the short, where the colored connectors go through the metal bracket under the left side cover, the wire on the other side of the solid brown wire, is ground out against the bracket...
- hiroshima1320
06 Jul 2012 18:48 #534312
by hiroshima1320
Wires fixed, floats set, battery charged. Misfire gone! Picks the front wheel off the ground from a slow roll! Running lights not working... Fuel guage started working though...
- hiroshima1320
06 Jul 2012 20:20 #534336
by hiroshima1320
All is good. I have a clear purolator fuel filter, and after putting about 200 miles on it, it looks fairly dirty. I guess I'll re flush my tank and put a new filter on.
