28mm w/accelerator pumps/ pods & 4-1
- School Teacher
28 Jun 2012 16:43 - 28 Jun 2012 17:07 #532406
by School Teacher
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
28mm w/accelerator pumps/ pods & 4-1 was created by School Teacher
This on a stock 1015 motor.
first off good to be back as i have not posted for a while.
2nd I'm getting lean popping at idle but mostly at 1/16-1/4 throttle
3rd the more I read about carb adjustment the more confused I get over the terms and what I have.
confusing to me is pilot screw vs idle mixture screw(air or fuel).
I have a screw coming in at an angle on the front(clean air side) of the slide is that a pilot adjustment screw or idle adjust? is there and idle adjust down by the bowls like on my 26's.((just looked again and there is NOT an screw here)
any help would be great. though I have cleaned them and they came off a running bike.
I have just been reading so much it is confusing....if that makes sense?(look at my name LOL)
1980 kz1000G1
Last edit: 28 Jun 2012 17:07 by School Teacher. Reason: update on bowls
- kawasaki mike
- kawasaki mike
- Thank you received: 4
19 Aug 2012 01:40 #543357
by kawasaki mike
Am addicted to Z1's and kz 900's have an el camino, fly rc helicoptors and am strung out on horsepower.
Replied by kawasaki mike on topic 28mm w/accelerator pumps/ pods & 4-1
do not know if you got help yet but yours is an air svrew. All it does is let more or less air into the carbs. I use 1 1/8 turn out on mine and am using 117.5 pilot with 120 mains. Thats what the plugs say do and it runs fine. Alot depends on your needle and the cut-away. My cut-away is 2.0. Happy tuning.
- Iheartkz
19 Aug 2012 12:55 #543413
by Iheartkz
1978 kz650 B pods kerker 4>1
1979 kz650 B3 pods kerker 4>1 accel pump
Replied by Iheartkz on topic 28mm w/accelerator pumps/ pods & 4-1
Also, Check and make sure your timing is correct, and points are properly gapped. Then go back to the carb.
