Mikuni BS34 CV idle mixture screws
21 Jun 2012 17:57 #530800 by gwolever
Mikuni BS34 CV idle mixture screws was created by gwolever
Hey guys. I have the Mikuni BS34 carbs and I am about to install them after cleaning and rebuilding them.
I don't remember what position the idle mixture screws were in when I took them apart, so I was wondering if there was a common position for these.
At this time, I have screwed them in all the way, and then backed them all out 5 turns...not really knowing what position they should be in.
Or am I supposed to just install them, run the engine and adjust according to the performance of the engine?
Anything else I should be doing before I install these back on my bike that you guys can think of would be very helpful as well.
Thanks guys.
1982 KZ1000 CSR
  • Motor Head
21 Jun 2012 21:19 #530842 by Motor Head
Replied by Motor Head on topic Mikuni BS34 CV idle mixture screws
1-1/2 to 2 turns from lightly seated will get you running, but each bike is a bit different with the final adjustment.
21 Jun 2012 21:34 #530845 by 750steve
Replied by 750steve on topic Mikuni BS34 CV idle mixture screws
Motor Head - How do you know when you've got it just right, what way does the engine behave?
Sorry for the thread hi-jack, i have no experience on setting up carbs but i cleaned mine, serviced them & replaced the jets
in = less air? Correct?
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
  • Motor Head
21 Jun 2012 21:37 #530847 by Motor Head
750steve wrote: Motor Head - How do you know when you've got it just right, what way does the engine behave?
Depends on the carbs, if the screw is behind the throttle slide. Then it is an Air screw, so in less air= richer. But if in front, then it is either a fuel or a volume of mixture screw. In =lean on fuel, etc.
21 Jun 2012 21:52 #530852 by 750steve
Ok, since they're nearest the cylinder head they're air screws?
So what do i need to look for to get that perfect setting?
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
  • Motor Head
21 Jun 2012 22:00 #530855 by Motor Head
I either didn't explain it right or you've misunderstood. If it is up against the head, in front of the slide valve, then it is an mixture screw. This will be In Lean, Out Rich. So these you have are the BS38 Mikunis on your twin? I'd say start about 2 turns out, with stock airbox and stock jets. With Pod's, you will need richer Pilot jets, and then still be around 2-3 turns out.
That's just the Pilot circuit.
To find the best setting is trail and err. you need to turn the screw in till the Idle speed drops, then back out about 1/4 to 1/2 turns and then run it. It might be farther out, end up at 2-1/2 turns or 3 turns, maybe 3-1/2. If any farther I would suspect vacuum leak, or still to lean a Pilot jet, with Pod's.
21 Jun 2012 22:39 - 21 Jun 2012 22:42 #530867 by 750steve
Yip, that was me, i misunderstood!
I have the BS38's too, started off 2 turns out & balanced the carbs........i've done nothing to the mixture screws since.
I'm running #50 pilots (or whatever is 1 up from stock) as im running pod's (yes i know :P , but its a cafe build & the stk airbox wouldn't look right), needle on clip #4 & 135 mains
I'll play with the screws tomorrow night & see what they do. I get a slight unburnt fuel sting in my eyes when the bike is ran in my garage for a while (but this might just be normal in an enclosed space) so i was going to start off going leaner but i'll keep an eye on the throttle response & judge it by that
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
Last edit: 21 Jun 2012 22:42 by 750steve.
22 Jun 2012 01:21 #530908 by gwolever
Replied by gwolever on topic Mikuni BS34 CV idle mixture screws
Thanks Motor Head.
Much appreciated!
1982 KZ1000 CSR
