- Thank you received: 5
Switching from BS34's to VM28's
- Marneman
20 Jun 2012 18:10 #530572
by Marneman
77 KZ1000-A1 "Bushido" Project
82 KZ1000 LTD "Terri Lee"
You know what, I don't have a one to some other number of douche-bag scale. So.. Six!
Switching from BS34's to VM28's was created by Marneman
OK.... I think I've reached my limit of tinkering with BS34's on my 82 KZ1000 J motor setup. All the jetting, synching, mixture adjusting , seal replacing that I can stand, and I am at the giving up on them ever being right stage. Could have bought a nice new smoothie setup for all the money and time ive spent messing with these turds.
So, thinking of replacing with a nice old reliable set of VM28's. However, not as straight forward due to the dual throttle cable setup necessary, different intake manifolds, airbox/pods setup and the like.
Does anyone have any recomendation for a set of right hand controls off of a modern sportbike, running a dual cable setup that may work with the VM28 setup? Thought about going to a vintage KZ aftermarket right hand setup, but it might be trick to go with something more modern?
Thanks.
Thanks.
- mtkawboy
- Thank you received: 16
20 Jun 2012 21:51 #530623
by mtkawboy
Replied by mtkawboy on topic Switching from BS34's to VM28's
They will work with one cable, it just isnt as safe. The 28s I have use a really stout spring so I dont see a problem
The following user(s) said Thank You: Marneman
- DoubleDub
- Visitor
20 Jun 2012 22:53 #530640
by DoubleDub
Replied by DoubleDub on topic Switching from BS34's to VM28's
APE and Motion Pro have reasonable push-pull throttle assemblies you can buy.
- kawasaki mike
- kawasaki mike
- Thank you received: 4
19 Aug 2012 01:52 #543359
by kawasaki mike
Am addicted to Z1's and kz 900's have an el camino, fly rc helicoptors and am strung out on horsepower.
Replied by kawasaki mike on topic Switching from BS34's to VM28's
You can ad a spring on the back side of the carb cable holder and bend the tangs to make them work. It gives just enough power to close the carbs.
- Old Man Rock
- Thank you received: 225
19 Aug 2012 10:25 #543394
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Switching from BS34's to VM28's
"Could have bought a nice new smoothie setup for all the money and time ive spent messing with these turds."... :laugh: :laugh: :laugh: Yup!
Now before everyine gets their panties all bound up... :pinch: Again... :whistle:
Nothing really wrong with the BS34's for a daily rider, cruiser etc... but as we've all discussed previously, for a performance build for power/acceleration, quick off the line pull, mid range - top end power pull etc... yeah need a different set of carbies no doubt.
As mentioned, go with the push/pull assembly and be done with it... Got mine @ Dynoman...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- zukdave
- Thank you received: 229
19 Aug 2012 13:34 #543420
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Replied by zukdave on topic Switching from BS34's to VM28's
I run my VM 29's with one cable a 1/4 turn Motion Pro throttle
and a return spring that's about 1/3 as stiff as stock and never had an issue.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
