Wanna buy a carb sync tool... is this one any good
  • AjKZBobber
  • AjKZBobber's Avatar
  • New KZ rider...Long time dirt biker
Re: Wanna buy a carb sync tool... is this one any good
24 Jun 2012 22:57
#531528
Old Man Rock wrote: Morgan Unit:
NOTE: How steady each carb measurement is.... Gauges fluctuate/bounce more making it hard to read.
Mine did anyways and that is when I went with the Morgan unit instead.
Color-Tune:
NOTE: Listen closely for idle/rpm changing when turning pilot/slow screw for blue...
RPM gets better with each carb adjustment for IDEAL A/F settings of each carb... ;)
Thanks for the videos. I think I may try the colortune plugs. If I was to use the colortune plugs, do I still need to remove the tank? I am trying to avoid this at all costs if possible since I really dont want to make a mess on the floor in my condos garage...its against the rules anyways.
1979 kz750 b4 twin bobber
  • Archiddeon
  • Archiddeon's Avatar
26 Jul 2012 22:46
#538879
Unfortunately you need to remove the tank for almost any carb adjustments. I suppose you might be able to do it with the tank on, but it will be very fiddly to get to all the parts underneath it.
A buddy and I worked on his bike in his condo's underground parking. Building rules likely differ, but they may be OK with it if you don't leave any mess when you're not there actively working on it. Otherwise ride it out to the street or a public parkade and do road-side work :P
1983 GPz 550
1985 Honda CH150 Scooter
1995 Suzuki GS500E
  • 0Z.Z1R Mk2
  • 0Z.Z1R Mk2's Avatar
27 Jul 2012 06:45
#538943
As above...it will be virtually impossible to sync the carbs without removing the tank.
Fuel tends to evaporate if you spill any anyway. ;)
1976 KH 500 triple
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
1982 GSX 1000S Katana
1983 GSX 1000S Katana
Don't knock my turbo lag - it gives your naturally aspirated a chance..
27 Jul 2012 09:06 - 27 Jul 2012 09:07
#538959
If you turn the petcock off and remove the fuel line where it attaches to the petcock you should only have a drop or two of fuel drip out of the petcock nipple. Keep some paper towels handy to catch it. Ed
Last edit: 27 Jul 2012 09:07 by 650ed.
