78 kz650, help!! please!!
Re: 78 kz650, help!! please!!
22 May 2012 20:53
More tips regarding clear tube testing --
The "special tool" isn't critical. And it's okay to just "self-thread" the clear hose snugly into the drain screw hole.
Also, a single screw is usually all that's required to hold the float bowl in position during the tang adjusting and bowl r&r's
Minimal leakage past bowl gasket and/or at the tube connection won't invalidate the test results (as fuel volume entering the bowl exceeds any leakage).
The following user(s) said Thank You: krazykzcommandeered
- krazykzcommandeered
23 May 2012 00:42
sweet, n thanks again, ill update tomorrow with the results, I had a friend tell me to soak em in acetone instead of carb cleaner, does this sound like a gd idea?
79 kz650 cafe rat racer
aka catchup
aka catchup
- ready2ryde1985
- got to love these kzs
23 May 2012 17:56
I know that bike !!! hahaha wasnt that a bunch of parts in a basement ... just givin ya crap bro im fighting mine tooth and nail lol
84 kz 700 a1
82 kz550 ltd
82 kz550 ltd
23 May 2012 19:12
ok took carbs aparts cleaned all the passageways like suggested, pilot was clogged on one, and floats where way off, after adjusting floats as suggested. she starts right up know, and idles fine, but now bogs down when the carbs are wide open, just running open headers, jetting maybe?
aka catchup
aka catchup
- munkybrain2010
- Clueless..
24 May 2012 02:16
If the jets are stock then you can definitely make it smoother with some proper jetting.
Keep it together man!
79 KZ650 "Geto Cycle"
24 May 2012 17:56
problem solved, did have floats way off, even after i adjusted them got to looking at the pic in didnt use the back of the bowl to measure. so re adjusted, n still ran like shit wide open, so checked the plugs, number two had a bad connection, and somehow amongst all the confusion i put a b7 in number one, re-re!
so made sure everything was the same n all the gapes right, n she runs better than she ever had. thanks guys for all the help
aka catchup
aka catchup
