Carb Advice
  • NakedFun
  • NakedFun's Avatar Topic Author
Carb Advice
18 May 2012 10:40
#523088
So I want some opinions or advice on the engine build on my '76 KZ900. The motor has 59,xxx miles on it, so I am going to start with a fresh rebuild and most likely a bore job. I will most likely do a 1015 big bore kit, bump the compression up, Dynatech Ignition, full exhaust, pods, and possibly a camshaft with adjustable timing gears. It will have all the supporting upgrades as well (valve springs, timing chain, studs, wleded crank, etc...) So my questions are:
1. What are the power and engine limitations on running a tuned set of VM26's that were on the bike? What are the benefits?
2. Is converting to the later BS34's worth the money and effort? What are their limitations?
I wouldn't mind giving up some top end power for a smooth and torquey powerband. I kinda like the thought of a mechanical carb instead of a diaphragm. Thoughts?
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
  • T_Dub
  • T_Dub's Avatar
Re: Carb Advice
18 May 2012 10:53
#523092
VM28's from a KZ1000 would be a lot better than the BS34's. Or a set of Keihin CR29's if you have the cash for that.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
  • Kawickrice
  • Kawickrice's Avatar
Re: Carb Advice
18 May 2012 11:21 - 18 May 2012 11:23
#523097
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationHere are some 28mm Mikuni's, 29's would be a nice touch to the motor if you can even find a set.
Here is a set of "Pumpers"
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Last edit: 18 May 2012 11:23 by Kawickrice.
  • NakedFun
Re: Carb Advice
18 May 2012 12:37 - 18 May 2012 12:42
#523119
I have almost every Kawi Mikuni carb set on EBay on my watch list. So the VM28's or Smoothbore 29's are what people are recommending?
Cory
1976 Kawasaki KZ900
Last edit: 18 May 2012 12:42 by NakedFun. Reason: I am an IDIOT!
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Away
  • Moderator
  • Moderator
Re: Carb Advice
18 May 2012 12:57
#523124
29s would be best, followed by 28s. Your 26s will seem weak up high, but do pull well from a dead dig up to about 70mph. But dont recommend 26s with a modified engine. I think WG carbs can bore out your 26s if so desired
  • NakedFun
Re: Carb Advice
18 May 2012 13:26
#523135
Bored out stockers might be a way to do it... Has anyone tried CVK36's from a Kawi ZRX1100? I have a ZRX and wonder if the carb spacing is the same? Thoughts?
Cory
1976 Kawasaki KZ900
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: Carb Advice
18 May 2012 13:45
#523142
NakedFun wrote: Has anyone tried CVK36's from a Kawi ZRX1100? I have a ZRX and wonder if the carb spacing is the same? Thoughts?
Cory
The ZRX uses a side camchain setup while the old Kaws use a center camchain setup. The spacing will be close to equal on the ZRX carbs but the KZ carbs will be paired left and right....if that makes sense.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • T_Dub
  • T_Dub's Avatar
Re: Carb Advice
18 May 2012 13:55
#523145
I wouldn't go teh boring route. Much cheaper/easier to get a set of 28's.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: Carb Advice
18 May 2012 14:16
#523147
T_Dub wrote: I wouldn't go teh boring route. Much cheaper/easier to get a set of 28's.
X2
VM29's may be a risky buy on ebay. many will be worn out or have toublesome parts.
I would put a set of Mikuni RS34's on your ebay list as well. if u come across a set, they will work well. some will say they r too big, but lots of guys r using them om KZ810"s.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • NakedFun
Re: Carb Advice
18 May 2012 15:52 - 29 May 2012 12:15
#523165
I am interested in the boring out of the VM26's. Since they will probable need a rebuild anyway, instead of buying extra carbs, have them taken out a bit. I have looked at the radial side 34's, but they are on the expensive side of things for a carb that may be a little on the sloppy side of responsive with the potential engine combination I am planning.
Yeah I figured the side chain vs. center chain of the KZ woud play a role in the carb spacing, but didn't know how much. I should actually measure it up tonight and see. Those carbs are plentiful and easily modded.
I'll keep my eyes open for a decent deal...
Cory
1976 Kawasaki KZ900
Last edit: 29 May 2012 12:15 by NakedFun.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: Carb Advice
18 May 2012 18:41 - 18 May 2012 18:46
#523203
personaly, i think if u want to gain performance, boring a carb is a bad move.
u just end up with a bigger carb, not a better carb. a 28 pumper would be a better choice than boring.
there is a reason that smoothbores perform better, and it is not because they r bigger.
u can find used rs34's for less money than $530 for bored carbs. and the rs34's will work better.
Just my opinion.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 18 May 2012 18:46 by mark1122.
  • Kawickrice
Re: Carb Advice
18 May 2012 19:40
#523217
From Georges website "works as well as a VM29 smoothbore WITHOUT the high price"
I am with Mark on this one. Works as well I doubt it, Sales and Marketing is what it sounds like to me. $539 is on the expensive side to me. Just saying
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
