rough ridin 81 kz750
- jdorsey
17 May 2012 15:54 #522939
by jdorsey
rough ridin 81 kz750 was created by jdorsey
hey guys.. new to the forums and hope someone can help me out. My 81 KZ750 runs pretty well most of the time but lately it's been doing something strange.
after riding for 10 minutes or so with the engine all warmed up and the choke fully off, the engine will nearly stall on me and I have to wring it's neck/throttle to keep it alive. this will last for a minute or two and then usually goes away.
I'm thinking it's the carbs but before I spend the $$ to rebuild them I'd love to know if its something more serious that would put the bike in the "too far gone" category.
any thoughts would be greatly appreciated.
thanks
thanks
- baldy110
- Thank you received: 512
17 May 2012 17:40 #522957
by baldy110
Replied by baldy110 on topic rough ridin 81 kz750
Check for vacuum leaks.
- Thank you received: 2829
17 May 2012 18:35 #522968
by 650ed
Replied by 650ed on topic rough ridin 81 kz750
How old is the battery? Ed
- Thank you received: 1656
17 May 2012 21:51 - 23 Feb 2013 16:09 #522995
by martin_csr
Last edit: 23 Feb 2013 16:09 by martin_csr.
- jdorsey
18 May 2012 14:43 #523151
by jdorsey
Replied by jdorsey on topic rough ridin 81 kz750
thanks for the tips guys.. i'll give them a try
(BTW, the battery was just replaced)
- 81KZ750E
12 Nov 2012 00:51 #557993
by 81KZ750E
Replied by 81KZ750E on topic rough ridin 81 kz750
question your suppose to run the bike in pri correct because if i take my tank off the bike and turn it to on or reserve it dosent have gas coming out but when it's on pri it comes flowing out pri is primary correct sorry i'm new to this and i just seen you said try runing the bike on pri in a post and i thought that's what your suppose to run it in.
- Thank you received: 2098
12 Nov 2012 01:01 #557997
by Patton
Replied by Patton on topic rough ridin 81 kz750
Vacuum operated petcock receives vacuum from a running engine via a nipple fitting on the carb or carb holder from which fitting a vacuum hose runs to the petcock.
When there's no vacuum being supplied by a running engine, there's a rubber diaphragm, o-ring and spring inside the petcock that prevents fuel flow in the ON or RES (reserve) position. When the engine isn't running, both ON and RES positions are the same as OFF. This design allows us retards to ignore any need to shut off the petcock when parking the bike.
PRI (prime) position by-passes the rubber diaphragm, o-ring and spring, permitting fuel flow without needing any vacuum. Same as a manual (non-vacuum) petcock in ON or RES position. For example, PRI could be used to fill the carb float bowls when the engine isn't running (i.e., when there's no vacuum being supplied to the petcock).
- gengomerpyle
- Thank you received: 17
12 Nov 2012 16:33 #558073
by gengomerpyle
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
Replied by gengomerpyle on topic rough ridin 81 kz750
if you leave it on prime without the bike running it will flood the engine
1982 GPZ750R1 ELR
1971 Honda CB750K
