Duralast Fuel Filter-Bad
  • kawaman21
  • kawaman21's Avatar
Re: Duralast Fuel Filter-Bad
05 May 2012 14:06
#519981
i'm glad to have read this thread,been having fuel flow problems on my lawson.got stranded 3 times and a few long pushes home.i have been using this car filter,it worked ok for a while but i was going nuts trying to figure out why the fuel won't flow.got a clear mesh one now and it seems to flow better,i'll try it through the week.
hee hee never touched me!
  • mtkawboy
  • mtkawboy's Avatar
05 May 2012 14:35
#519985
You will find thast was the problem, I went thru the same thing, thinking coils, ignition etc
  • blipco
  • blipco's Avatar Topic Author
  • 2002 KZ1000P
05 May 2012 16:46
#520009
I'm swapping mine. I didn't have a problem with flow but why should I? The paper element was just laying there not filtering or blocking anything.
  • loudhvx
  • loudhvx's Avatar
05 May 2012 21:08
#520047
mtkawboy wrote: Might as well switch over, the paper ones just dont work any more. I limped home 3 times on my Gs1100 thinking I was having coil problems. It would run around town when the filter was brand new but when you got it up to 60 or so it would run out of gas. After a week it wouldnt even run around town.I Finally stuck a bronze Custom Chrome filter on and it was fine. It has to be the new gas, I used them for years with no problems
I also used those paper ones for years. Then about 7 years ago I started having problems with them. It seems like the glue dissolves over time, then re-settles on the paper, sealingit off after awhile. That's all I can figure. Like you said, maybe new gas is dissolving the glue where the older gas (without alcohol) did not.
  • MFolks
  • MFolks's Avatar
05 May 2012 21:12
#520048
More information about Ethanol in gasoline:
1. Ethanol can break down resins and fillers in fiberglass gas tanks, causing them to leak.
2. Resins leached from fiberglass tanks can go through the fuel system, sticking to valves and other internal engine parts.
3.These deposits have caused bent pushrods and have clogged intake valves.
4.The alcohol attracts water, leading to increased corrosion in metal gas tanks.
5.Water in the fuel affects the octane and leads to knocking and decreased performance.
6.Ethanol acts as an efficient solvent, gradually cleaning out the accumulated gunk in fuel tanks and lines, and clogging carburetors.
7. Certain rubber gaskets and fuel lines are weakened by ethanol.
Our Goverment at work!
  • blipco
  • 2002 KZ1000P
06 May 2012 20:41
#520305
UPDATE: Apparently I was wrong. I thought my filter degraded over the course of the winter while in storage. It takes LESS THAN A WEEK!!! Maybe a couple of days. My new one already crapped out!!! No more paper filters for me.
