new carbies for old z400
- jsbrodie
01 May 2012 15:18 #519113
by jsbrodie
new carbies for old z400 was created by jsbrodie
Hello,
I have recently bought a 1975 z400. And the carbies are both shot. Can someone please recommend/advise on what carburettors I can choose from? ie; do I have to look for same year/model?
Thanks!
Thanks!
- DoubleDub
- Visitor
01 May 2012 16:09 #519122
by DoubleDub
Replied by DoubleDub on topic new carbies for old z400
What's "shot" about them?
- jsbrodie
01 May 2012 19:35 #519174
by jsbrodie
Replied by jsbrodie on topic new carbies for old z400
one is completely corroded and the other has been broken and glued back together, so it appears.
- Bullpen
27 Jul 2012 16:21 #539050
by Bullpen
Replied by Bullpen on topic new carbies for old z400
I have the same question right now with a bike I just picked up... Did you ever find the answer to this question? I don't need anything original, just something that will function.
- Thank you received: 2237
28 Jul 2012 21:57 #539267
by TexasKZ
Replied by TexasKZ on topic new carbies for old z400
Almost any carb near the size of the originals will "work," but there can be many complications. Spacing between the carbs is important and often unique to a particular engine family. Non stock carbs may be fine, but they will need to bolt to the stock rack and they will need the proper width linkage between them. Using stock carbs is often much easier. Kawi made about a buzillion kz400s, so a good used set should not be difficult to find.
