- Thank you received: 229
VM 29's gpz 750.
- zukdave
08 Feb 2013 09:41 #571466
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Replied by zukdave on topic VM 29's gpz 750.
Kevin I ended up with the 17.5 pilot and 117.5 mains
and the 0-6 needle jet.
I think next time at the track I'm going do run
some 120 mains as I think it's laying down a little in the lights
and not pulling the MPH I think it should.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- donthaveakawman
- Visitor
08 Feb 2013 17:04 #571506
by donthaveakawman
Replied by donthaveakawman on topic VM 29's gpz 750.
I got some b7es and they are cleaner after hundreds of miles. probably due to the higher heat range.zukdave wrote: Rest of the story.
Started with 117 mains and think it's running lean.
Idle I get little responce from the air screw's
and off idle to lower mid range suck's.
1/2 throttle up seems to be close so after dinner
I'm gunna check float level again ans see were the needles are set.
New plugs after a 30 mile city/hiway ride.
- zukdave
09 Feb 2013 21:24 #571657
by zukdave
And so do the rest of us.
The thing you don't have is a set of VM29 smooth bore carb's
so come back when you know what you're talking about.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
I got some b7es and they are cleaner after hundreds of miles. probably due to the higher heat range.[/quote]donthaveakawman wrote:
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- donthaveakawman
- Visitor
10 Feb 2013 00:23 #571685
by donthaveakawman
what is the point in 29 mm carbs with a head that is designed for 36 mm carbs?
