TK 22 carbs missing choke valve flaps
- Gar1800
04 Apr 2012 11:20
Doh! I have to eat my words, I thought I could feel the choke flaps with my fingers, after removing the carbs I have discovers they are all indeed missing. I have read that the holes where the flaps where could be filled and I could just use the choke manually. I would like to hear from anyone who has done this, and how to go about filling the holes in.
The following user(s) said Thank You: Gar1800
- loudhvx
Re: TK 22 carbs missing choke valve flaps
04 Apr 2012 12:26 - 21 Jul 2014 09:25
But actually, it was Apbling who has done it most recently.
He sealed them off, but that required messing with the choke too much while warming up. If you can wait for the bike to warm up, (or only ride in warmer weather) it may work, but in the end he ended up making new flaps.
Turned out pretty good:
kzrider.com/forum/3-carburetor/504518-55...aps-fabrication-pics
www.kzrider.com/forum/23-for-sale/594757...t-original-equipment
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 21 Jul 2014 09:25 by loudhvx.
- Gar1800
04 Apr 2012 13:55
Gabbing some would be the way to go, but I have no way of doing this myself. Epoxy doesn't sound like the best route. I will call the local bike yards, maybe just get a set of parts carbs then.
Gar
Gar
- Gar1800
07 Apr 2012 20:15
I just did the e-bay thing and have a set of carbs (with choke flaps)coming from a salvage yard. I cant wait to put them in... then again I have no idea how to tune the carbs so more reading here and silly questions will be the next step. I just remembered I have to check another thread and get the right size jets because I will be using emgo pod filters. More reading!
Happy Easter weekend to all.
Gar
Gar
Attachment IMG_1326.JPG not found
Attachment 105_3294_2012-04-07.JPG not found
- Rustybucket
04 Mar 2019 18:40
eBay has them. Search kz550 choke flaps or choke valves.
- Rustybucket
05 Mar 2019 04:36
eBay sells just the choke flaps / valves for around $35. You can replace them without having to remove the carburetors and it's pretty simple. I did it myself and only took about 30 minutes.
Attachment not found
