- Thank you received: 1
Overflow pipe crack
- Brett0424
27 Mar 2012 16:35 #512328
by Brett0424
80/81 KZ440 frankenstein
Overflow pipe crack was created by Brett0424
I have a 1981 KZ440. I thought my float level was off because fuel was leaking out the overflow tube. I opened up the carbs and one of the overflow pipes is cracked right down the middle. The other has a small hole. Is there any way to fix this? Is it even possible to find new bowls? I read online about someone soldering the crack, will that really work safely? Thanks.
Brett
Brett
- KZJOE900
- Admin
27 Mar 2012 16:43 #512330
by KZJOE900
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Replied by KZJOE900 on topic Overflow pipe crack
Some people put a piece snug fitting tubing over it. Seems the easiest way. Myself, I took suggestion from here and soldered it. Seems more permanent IMHO.
Before
After
Before
After
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- Brett0424
27 Mar 2012 17:03 #512334
by Brett0424
Replied by Brett0424 on topic Overflow pipe crack
What are the steps for soldering it? Thanks so much that's exactly what mine looks like.
- Thank you received: 2098
27 Mar 2012 17:04 #512335
by Patton
Replied by Patton on topic Overflow pipe crack
Or JBWeld.
Or heat shrink tubing.
- Thank you received: 2829
27 Mar 2012 17:15 #512342
by 650ed
Replied by 650ed on topic Overflow pipe crack
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationI would just replace the bowl. Be sure to get the correct one:
- baldy110
- Thank you received: 512
27 Mar 2012 17:24 #512347
by baldy110
Replied by baldy110 on topic Overflow pipe crack
JB weld is good stuff but does not stand up to direct exposure to gasoline. It will eventually break down.
- testarossa
- Thank you received: 82
27 Mar 2012 17:42 #512352
by testarossa
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
Replied by testarossa on topic Overflow pipe crack
I soldered mine and it held up just fine. The main thing is to get everything very clean and dry before you solder. You probably need to use a small butane torch. I don't know if an electric gun will work.
2004 ZX-10R
Angola, IN
- Brett0424
27 Mar 2012 19:28 #512380
by Brett0424
I have a torch. Is there any special solder I need? Should I flux first?
Thanks again
Thanks again
- JR
- Thank you received: 449
27 Mar 2012 20:05 - 27 Mar 2012 20:11 #512382
by JR
Replied by JR on topic Overflow pipe crack
I got thin brass tubing at a hobby store. Cut the right length, slipped it over the existing tube and soldered all around the bottom using electrical cored solder, the type that has the flux built in. That was 7 or 8 years ago.
I used a soldering iron usually used for electrical. Worked fine. I have never used a torch but would suggest being carefull not to melt the bowl which is made of cheap pot metal.
Last edit: 27 Mar 2012 20:11 by JR.
- nobody
- Thank you received: 7
27 Mar 2012 20:46 #512389
by nobody
Replied by nobody on topic Overflow pipe crack
elc probable ok deepens on heat ,watts of gun and it never hurts to use flux makes solder flow better the key word is flow good luck not that hard .ps cleaner is better
- Brett0424
27 Mar 2012 22:32 #512404
by Brett0424
So I torched it and soldered it, took a while to get it right, then when I went to sand down some excess solder the tube was so flimsy it broke off. Called a local shop and he said they have tons of used ones, I'll pick them up tomorrow. When I bought this bike one of these overflow ports was plugged and one was vented but the hose was stuck up real high, now I know why. I'm wondering if that could have been part of my idle issues. If your float level is in check do these things need to vent, could you run with them just plugged? I promise I'll stop asking questions after this.
- KZJOE900
- Admin
27 Mar 2012 22:40 - 27 Mar 2012 22:41 #512405
by KZJOE900
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
You don't want to run them plugged up. If you do, and your float needle gets stuck open, then the only place the fuel has to go is into your cylinders and then crankcase from there on. You will then have contaminated oil which will need to be replaced. You should always have these overflows working properly and shut off the petcock when the bike is parked as well.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Last edit: 27 Mar 2012 22:41 by KZJOE900.
