Need a pic of throttle cables attached to carbs z1
  • fivestring
  • fivestring's Avatar Topic Author
23 Mar 2012 21:03
#511542
I am at a loss on what is going on with my pull and push throttle cables. I know PO said he swapped in a set of carbs recently but me thinks the bracket that holds the cables at the carb assembly is not kosher for this bike. Here's what I have now. Don't laugh or give me grief about my zip tie fix...
I would like to know what 'normal' linkage should look like so I can get the parts I need to make this right.
4 out of 3 people have trouble with math
Current
1978 KZ1000A2A, hardtailed, bobbed and stretched
my build thread
1977 Yamaha XS750 (parting out)
1978 Honda CB750 Four
1981 Yamaha XS650
1982 Yamaha XS650
Former
1980 Kawasaki CSR750
1980 Suzuki GS850L
1982 Suzuki GS1100K
1987 Suzuki GSXR1100
1985...
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
Re: Need a pic of throttle cables attached to carbs z1
23 Mar 2012 23:35
#511567
I do not have a pic to show you.
Not sure from your pic but it looks like you have a set of BS carbs on your Z1. If that is the case the BS carbs use a single cable - not the 2 cables used by the stock vm carbs on the z1. The single cable for the BS carbs has a smaller end to fit into the cup at the carb bracket.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • nobody
  • nobody's Avatar
24 Mar 2012 05:06
#511599
what he said. ;) do you run it with them vacuum ports open on the carbs ? :unsure:
  • fivestring
24 Mar 2012 10:57
#511634
No, I moved the tubes for the picture.
I did some searching and it seems I have BS34 carbs.
So, what cable would I need to put on there for it to be the correct one for the carbs? The carb assembly is set up to use two cables. I don't know if that is technically called pull/pull or pull/push but I am guessing the handlebar end of all the cables would still fit the stock throttle grip. It would be nice for them to bolt up to the carbs in a proper way.
I think I'll snap some photos all over and post them on here so I can find out what is stock and what has been changed on this monster. I was on the gallery looking at pictures of kz's and I discovered my swing arm is not original with a 4" stretch like PO said.
I don't want to sound like I'm clueless, I just never owned a kz or was ever around one enough to be familiar with them. So I have no reference for stock setups, except for you folks.
Thanks.
Current
my build thread
1981 Yamaha XS650
1982 Yamaha XS650
Former
1980 Suzuki GS850L
1982 Suzuki GS1100K
1985...
  • nobody
  • nobody's Avatar
25 Mar 2012 01:17
#511802
cant send you a pic of stock right now but can tomorrow will this work for you ????
  • DiamondSkyBlue1000
  • DiamondSkyBlue1000's Avatar
25 Mar 2012 01:57 - 25 Mar 2012 02:26
#511809
I put BS34 carbs on my 77. Same thing as you have. I simply removed the "push" cable (the one towards the back.) You shouldn't need the zip ties. The cable sheath end just sits in the holder. Once you set up the cable length and tension, the closure spring on the carb linkage will hold everything in place.
Removing the "push" cable from the throttle housing on the handlebars will give you a chance to inspect the cable end on the "pull" cable. When I did mine I found my "pull" cable end was on its last strand and about to break. Also, my throttle was in bad need of cleaning and lubrication. Use a little chain lube between the grip and the handlebar and also on the cable end, it works wonders.
I can send you pics tomorrow as well.
Mine also has the bracket for what looks like a push/pull cable setup but there is no cable I've found that will fit that "push" bracket. It's way too far from the linkage, I see the zip tie is trying to compensate for that on yours. Maybe it's some special Police requirement? I dunno. BS34's don't really need a push cable.
Those two nuts on the pull cable, when you finish setting the length and tension, you should have one nut under the bracket and one on top. There is an adjustment at the throttle on the handlebar as well to get the length correct. If you can't get the length to accommodate the over/under nut placement, no worries, just set the cable up with both nuts on the top of the bracket and use the upper nut as a jam nut against the lower nut to keep it from loosening up. Like I said before, the closure spring will hold everything nice and tight against the bracket.
Last edit: 25 Mar 2012 02:26 by DiamondSkyBlue1000.
  • nobody
  • nobody's Avatar
25 Mar 2012 22:16
#511982
hear is a pic :unsure:
Attachment kzcarbsnewonbike002.jpg not found
  • fivestring
26 Mar 2012 10:40
#512070
Wow! Thanks for the pics and all the help!
I was thinking, too that the whole thing didn't really need a push cable. When I removed the carbs I noticed there are four return springs built onto the butterfly shaft between carbs. I also noticed two of the four were not installed to have any tension on them. SO I fixed those ends so all four were pulling the butterflies closed and that alone made it much more snappy going closed. I failed to mention that the last time I ran the engine, it didn't want to go back to idle as fast as it should without reaching down and manually pushing on the linkage.
Diamond, my push cable is just like you said, way too far from the linkage to be mounted in the bracket. Right now the cable housing end is actually under the bracket where it is supposed to be mounted, thus the zip tie.
If I drill the pull mount big enough for the threaded portion of the pull cable to be'nutted' in place above and below the mount, the cable will be too long. It has to stay right about where the pic shows now.
Nobody, great pic. That is what I want to accomplish. What is your year/model? And is that all stock?
I haven't started the bike since changing it to the way it is in the picture. I'm sureit is better than before. But zip ties do not a permanent cure make. :)
Current
my build thread
1981 Yamaha XS650
1982 Yamaha XS650
Former
1980 Suzuki GS850L
1982 Suzuki GS1100K
1985...
27 Mar 2012 00:13
#512237
Sorry so late, been busy!
  • nobody
  • nobody's Avatar
27 Mar 2012 00:32
#512239
looks good i should have told you i think you would have to change cable. to long or short any way.yes it is stock 1982 kz1100 d .if you would like to see more look under nobodys kz .its getting there. but slow thanks
  • fivestring
31 Mar 2012 02:02 - 31 Mar 2012 02:09
#513113
I finally got a chance to redo the throttle linkage. I removed the push cable altogether. Then I did some cutting and welding on the cable holding bracket. Here's what I came up with...
Before...
After...
Current
my build thread
1981 Yamaha XS650
1982 Yamaha XS650
Former
1980 Suzuki GS850L
1982 Suzuki GS1100K
1985...
Last edit: 31 Mar 2012 02:09 by fivestring.
  • nobody
  • nobody's Avatar
31 Mar 2012 03:21
#513116
looks good dose it return on its own?? is it smooth ????? what you doing with valve cover off :unsure: ??hope its not a bad thing. well take care
