Lubricating carburetor linkage and slides
  • bluej58
  • bluej58's Avatar Topic Author
17 Feb 2012 21:52
#504756
Please recommend a good oil to use on carb linkage and slides.
JD
78 KZ1000 A2A
  • Andy Lishious
  • Andy Lishious 's Avatar
Re: Lubricating carburetor linkage and slides
17 Feb 2012 23:12
#504776
Zepreserve is more than adequate
1981 Kawasaki kz750 E 160 pound rider
1973 Bultaco Alpina 250
18 Feb 2012 00:07 - 18 Feb 2012 00:14
#504786
Use nothing on the slides. Use a tiny bit of motor oil on the linkage and where the choke "starter plungers" enter the dust shields. Use motor oil to lube the cables. Use white lithium on the throttle grip. Take a look in the beginning of the Kawasaki Service Manual. It describes where to lube everything (not just carb stuff) and what to use. Ed
Last edit: 18 Feb 2012 00:14 by 650ed.
  • bountyhunter
  • bountyhunter's Avatar
18 Feb 2012 01:38
#504807
You definitely put NOTHING on slides. I used some light grease on the linkage pivots. For throttle, clutch cables I hung them up in the garage and hosed down (inside) from the top with teflon multi purpose spray lube (with teflon).
  • Andy Lishious
18 Feb 2012 02:37
#504815
Everyone has there own opinion just go with your gut youl be okay
  • BlackZ1R
  • BlackZ1R's Avatar
  • Kawasaki in my blood
18 Feb 2012 03:05
#504817
Andy Lishious wrote: Everyone has there own opinion just go with your gut youl be okay
BS! I think you're missing the point. Don't go by your gut when you don't have a clue about what you're doing. Ask questions and listen to the answers given by the guys that know.
Go by the manual, 650Ed isn't telling you wrong. This guy, on the other hand, meh... :S
:whistle:
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
  • Andy Lishious
18 Feb 2012 03:19
#504821
Your just mad cause i wont sell you my fcr.lol
  • bountyhunter
18 Feb 2012 03:55
#504823
At least nobody recommended WD-40........ :laugh:
  • BlackZ1R
  • BlackZ1R's Avatar
18 Feb 2012 11:34
#504843
Andy Lishious wrote: Your just mad cause i wont sell you my fcr.lol
Mad? Not hardly. Your inexperience is obvious in your posts,
I was trying to help you get your bike sorted with a set you could use instead of you butchering a good set of carbs.
Kawasaki
  • DoubleDub
  • DoubleDub's Avatar
18 Feb 2012 11:36
#504844
bountyhunter wrote: At least nobody recommended WD-40........ :laugh:
I can if it would help.... :blink:
  • bluej58
18 Feb 2012 15:03
#504879
Thanks guys, motor oil on the starter plungers, that's cool.
NO lube for the slides !!!
I'm in the process of cleaning them off including the WD 40 I sprayed on them to loosen the grim :pinch:
I'm using Simple green and carb spray.
So I'll hit all the linkage with oil and lithium under the grip.
I bought the cable lube and luber tool from Z1
78 KZ1000 A2A
18 Feb 2012 15:18
#504882
bluej58 wrote: ... lithium under the grip....
Shouldn't need any grease on the handlebar under the throttle sleeve.
A clean dry fit should allow ample clearance and free rotation.
The grease is used inside the throttle housing where the cable ends and ferrules are located.
Good Fortune! :)
