tygon gas pipe, doesn't go brittle or crack!
- steelhorseangel
- ad@wildlifeartist.plus.com
17 Feb 2012 16:07
hi kzr's
i've just discovered this new product called tygon!
Tygon® Formulation F-4040-A Tubing
A consistent performer lot after lot, Tygon® Fuel and Lubricant Tubing is the most requested fuel and lubricant tubing for a variety of applications -- from small engine fuel lines to coolant transfer. Specifically designed to handle most fuels and industrial lubricants, Tygon® Fuel and Lubricant Tubing resists the swelling and hardening caused by hydrocarbon-based fluids. This significantly reduces the risk of failure due to cracking and leakage. Its minimum extractability safeguards the liquid or vapor being transferred against adulteration.
Extremely flexible (Shore A, 57), Tygon® Fuel and Lubricant Tubing simplifies installation, even in tight places. It is translucent yellow for positive identification and to allow easy flow monitoring. It is routinely used to handle gasoline, kerosene, heating oils, cutting compounds and glycol-based coolants.
Features
• Resists embrittlement
• Compatible with most petroleum-based products
• Resists swelling and cracking
• Ozone and UV light resistant
q) what is the point of putting lower spec gas pipe on your bike that will go hard
with time, crack and leak!... do it once, do it right!..
Features
Attachment prodf4040a.jpg not found
Angel
Restore, Wrench & Ride!
Brought up with Dad, brother, all riders!
Our Dad (Eric) taught us both simple mechanics
before he went to the happy hunting ground, too soon (44)
My KZ is now called Eric and he will ride and protect me!
x God Bless x
x God Bless x
Last edit: 19 Feb 2013 12:47 by martin_csr.
Re: tygon gas pipe, doesn't go brittle or crack!
17 Feb 2012 16:46
www.vitosperformance.com/atv_parts/produ...id=85&cat=353&page=1
i have been using the stuff in the link for the last ten years or so.i got started using it on my banshee when i was racing.
i really like the fact that i did not have to use clamps and it would seal off and not leak.
after several years it did get hard and a little bit discolored,but i figured i had gotten more than my moneys worth from it and did not mind replacing it with the same thing.
i think they have come along ways with the fuel resistant rubbers and plastics.
- RonKZ650
17 Feb 2012 20:27
I've used quite a few different Tygon fuel hose in both rubber and plastic tubing type and all of mine has hardened/yellowed/cracked after several years. I see this hose in question is rated to 165 degrees F. I think the problem is motorcycle engines behind the cylinders is much higher than this. I don't know anything particular to this hose here, so it may not exhibit the age old problem of rubber and heat, but just by looking at the picture, I would guess that it would be rock hard in less than 2 years.
17 Feb 2012 20:39
I tried various clear tubing with poor success. I switched to regular automotive 1/4" fuel line from Pep Boys. It's been on the bike for more than 4 years and it's still as flexible as the day I bought it. Here's a pic of the stuff:
Attachment FuelLine.jpg not found
- ramtough_63
18 Feb 2012 00:48
I put clear line on mine I got from one of our favorite venders and it has turned color in just a few short months it's still pliable but not as pretty as it was. Tygon is used for chemicals of all blends and seems to have found a home in the medical industry but I am using it on my brake resivoir I hope it doesnt turn colors as it is exposed
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- z1kzonly
18 Feb 2012 01:01
I've been using tygon for 20 years. Paul Gast "FBG" been using it too, thats were I get mine.
Ultra violet rays UV is what does most line in. You never see dried out neoprene hose under a car hood or frame.
- TeK9iNe
- What did you do!?!
18 Feb 2012 01:20 - 18 Feb 2012 01:20
Yeah, its the UV. The plastic clear stuff doesnt like heat either, not so much as the rubber lines will handle.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 18 Feb 2012 01:20 by TeK9iNe.
- etbike3135
18 Feb 2012 08:36
Tygon is cool and works great but it does need to be replaced every few years. Lately I have been going back to black rubber from the auto parts store.
1973 Kawasaki Z1
18 years in dragbikes
