carb question
  • Vannod
  • Vannod's Avatar Topic Author
carb question
26 May 2006 16:13
#50338
Hello all.
I seem to run into a litle stump. I bought 2 carb rebuild kits, and went right to work. Knowing a little carbs already, once apart. I located and cleaned all the jets tubes and what-nots on the inside. Only problem is. The parts I have left to replace seems to be air fuel mixture spring, o-right, and needle. Problem is, I cant seem to get that darn tiny disk/plug out of the carb to replace it and everything underneigth. Now, I can probibly put in a small hole and pop it out with a screw, but I guessing there is probibly a better way to do this. Any help is greatly appriciated.
  • wiredgeorge
  • wiredgeorge's Avatar
Re: carb question
27 May 2006 06:55
#50421
Drill a hole. Take care not to drill too deep or you will hit the screw and pop it out with a nail or screw. It is easier to shoot it out with a .45 cal but that will sometimes damage the carburetor, depending on your accuracy.
  • heartless
  • heartless's Avatar
Re: carb question
27 May 2006 07:02
#50423
i used a small drill bit (1/8th or there abouts) and a hand driver to carefully drill hole into the disk, soft aluminium, easy to drill - then popped the disk out using an awl.
have not used the replacement disks at this time...
WG - the 45 works, but thinkin a smaller caliber might be a better idea - no point in "overkill" ;) :ohmy:
Post edited by: heartless, at: 2006/05/27 10:04
  • Vannod
Re: carb question
27 May 2006 12:33
#50471
Thanks for the help. Was thinking that was the better way, but I guess the drill will work too:evil:
