polishing up the tops and bowls :)
30 Jan 2012 17:23 #500895 by bearshawk
polishing up the tops and bowls :) was created by bearshawk
i polished up the tops and bowls of my VM 24's after a thorough clean, replace of O rings, fuel lines and bench sync, wed i will get her running and do a full sync and get her running juusstt right, but this is the best the carbs have looked since i have got the bike :)
just a sneak peak
has anyone clear coated the tops so they stay shiny?
1978 kz650 sr- long time project/first bike mostly gone
1979 kz659 sr- new acquisition NEXT project GONE
Both 650s combined to make one great bike! with a new powerplant
it is a 79 frame, 78 front end, both 78 wheels and brakes, 78 body work and a 80' 750-4 motor with gpz 750 cams and a kerker and...
30 Jan 2012 17:45 #500900 by KZJOE900
Replied by KZJOE900 on topic polishing up the tops and bowls :)
Looks good! I did the same to my tops and bowls but they don't seem to last. I learned from a site that sells aluminum polish not to use any silicone based waxes on aluminum because it will dull the shine. They recommend a bees wax of some sort to keep them protected and shiny. Haven't tried the clear only because I am leery about the clear yellowing with the sun and the heat from the engine. I still may try it and even have purchased a hi temp engine clear.
Joe
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
01 Feb 2012 07:44 #501265 by fxdl2051
Replied by fxdl2051 on topic polishing up the tops and bowls :)
Looks good, what kind of polish did you use. I've been using Wenol on my cases and rims and can't seem to remove some of the deeper discoloration from them, it's really bugging me.
