fuel injection/fuel pump
- shawnschallenger
23 Jan 2012 16:17 #499628
by shawnschallenger
fuel injection/fuel pump was created by shawnschallenger
Hi im new to this site my name is shawn im from WI i have a question for anyone im thinking about buying a 1980 KZ1000 classic with fuel injection the bike is in great condition runs awsum but the fuel pump went out and of course i cant find one my question is can i use a fuel pump for a car as long as its pumps the same pressure has anybody done this or can it be done any thoughts on this subject i would greatly be appricated thank you my E mail is shawnhammes45@gmail.com thanks again
- DoubleDub
- Visitor
23 Jan 2012 16:29 #499630
by DoubleDub
Replied by DoubleDub on topic fuel injection/fuel pump
Don't know for sure, but there are two things that I can think of to consider:
1. The bike doesn't generate as much electricity as a car does, not sure how much draw a car pump would create.
2. Size is an issue on a bike, not so much in a car.
- steell
23 Jan 2012 19:42 #499674
by steell
Replied by steell on topic fuel injection/fuel pump
Walbro GSL 393 is almost identical and is readily available.
Or if you want to go the cheap way, same pump on 87-90 Ford F150 trucks with the 4.9L six. May be on the V8s also, never checked.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
23 Jan 2012 19:47 #499676
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic fuel injection/fuel pump
Yeah, as long as same pressure/flow rate and 12V, you're good to go.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- MFolks
- Thank you received: 540
23 Jan 2012 20:12 #499681
by MFolks
Replied by MFolks on topic fuel injection/fuel pump
Your pump probably produces PSI at Idle, and 35 PSI when the throttle is moved. Try tese suppliers:
Fuel Pumps & Regulators
www.fuel-pumps.net/gsl393.html
www.mpsracing.com/products/MPS/FuelPumps.asp
www.airtexproducts.com/
- Motor Head
- Thank you received: 391
24 Jan 2012 00:12 #499722
by Motor Head
Replied by Motor Head on topic fuel injection/fuel pump
Since there is a 90 degree fitting on the end of the stock pump, it would require some refit to run another. Otherwise a replacement should be straight forward. The pressure is handled by the regulator, and an adjustable one would be a good Idea. Then you will have some tuning available.
Have you checked the pumps input screen to see if it is plugged?
Does the pump turn when using jumper leads and a 10 amp in-line fuse?
If not look at the Double relay, one side is for the pump, the other the Computer.
