When to re-jet?
- Serpent7
- Nothing professionally, only for fun...
Thanks!
19 Audi Q5
14 Volkswagen Touareg X
97 Honda Shadow Spirit
79 Kawasaki KZ1000 st
79 Volkswagen Transporter
73 Volkswagen Thing
- Thank you received: 2829
- TeK9iNe
- What did you do!?!
650ed wrote: If you are running the stock airbox & filter I would start with the stock jets and new spark plugs. Then run it a couple days to see how it performs, check the color of the plugs, and adjust jetting only if necessary. Ed
+1 Good advice. Give it some time to judge it - especially over some weather change days.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Boostable
- Thank you received: 13
+2... It's unanimous!! Always start stock and work up from there. Need a good foundation to start with, so your not guessing.
~Jack
1982 KZ1000 J2 ~ Project (Street Fighter - Project Section)
1976 KZ900 - Daily Rider
- Serpent7
19 Audi Q5
73 Volkswagen Thing
- mark1122
- Keep twisting it
- Thank you received: 109
if it was, then it stands to reason that u will need to duplicate this cab profile with the new carbs, providing the new carbs are exactly the same .
as stated above, u can start with the stock jets, but if it doesnt run right , just swap all the jets. keep track of where the air screws are set, on the original carbs. for example, if they are 1 1/2 turns out right now, record that info for latter use.same with the needle clip position. write down every jets #,(for each set of carbs) so u have all the info on hand and then u wont get the 2 carbs jetting , mixed up.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- andy9802gt
- If it tastes that good, eat it yourself.
- Thank you received: 18
mark1122 wrote: was the bike running fine, with all of these mods and current carb set up, at one time??
+1. Also, only tune one circuit at a time so you know which one to change if it's not right. If you raise the needle and change the main jet it's hard to say which one is making it stumble.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
- Serpent7
Bike ran ok, but in my opinion not great. The original carbs I took apart and cleaned them as well as I could, seafoamed the heck out of them, but I went ahead and bought cleaned andpolished carbs to see if they make a difference. I also noticed I had cracks in my original coils, so today(so excited) I ordered a Dyna 3ohm dual coil, and a dyna S ignition kit, petcock rebuild kit, and accelurator pump rebuild kit. So now, I'm going to wait until all my parts arrive and install them all at once. Also, going to sell my original 28mm carbs with either the stock jets, or the stage 1 jets that I have. All really depends on how the bike runs with all the new stuff installed.
19 Audi Q5
73 Volkswagen Thing
- bountyhunter
- Thank you received: 337
- Serpent7
Yep! 4 into 1 has no baffle. I was thinking I should swap over my stage 1 jets and start from there also.bountyhunter wrote: Does your 4-1 have a reasonable baffle in it or closer to straight pipe? If the former, start with stock jettig and adjust,=. If the latter, swap over the old setup for starters and adjust from there.
19 Audi Q5
73 Volkswagen Thing
