tips for carb rebuild??
  • ed spangler
  • Topic Author
  • Tennessee Z
21 Jan 2012 15:04 #499242 by ed spangler
tips for carb rebuild?? was created by ed spangler
I have a manual for Mikunis that is a "universal" type manual. Looking to see if anyone like a manual or rebuild guideor anything you can post or send me specifically for the stock carbs on my 75 Z1-B 900, gonna be taking them off the bike in a month or so, taking them apart, already have carb kits, rubber plugs for synch ports, and rubber seal for choke shaft. Wondering if anyone has any suggestions that I may need something else i.e. O-Rings for anything that are not normally included in carb kits? Think the stock carbs are 28's?
Thanks Ed aka TennesseeZ
Have 1975 Kawasaki Z1-B & 2003 Harley Davidson Heritage Softail Classic
Had Hondas, Harleys and many ,many Z Series Kaws both Std. & LTD's
  • Motor Head
24 Jan 2012 01:25 #499740 by Motor Head
Replied by Motor Head on topic tips for carb rebuild??
There is some really great carb info in the "File Base", top right corner of the KZR toolbar. The VM Mikuni is very similar between models, so even though some of the write ups are for a smaller series from a 650, much will be similar.
24 Jan 2012 08:47 #499777 by Old Man Rock
Replied by Old Man Rock on topic tips for carb rebuild??
Here ya go Ed....
As motor mentioned, same carbs for the most part. ;)
VM Carb Build/TUning
Then another I put together on Carb theory, jetting, sync etc...
Carb Theory/Jetting
Good luck,
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
24 Jan 2012 10:22 - 19 Feb 2013 13:47 #499783 by martin_csr
Replied by martin_csr on topic -
Last edit: 19 Feb 2013 13:47 by martin_csr.
