- Thank you received: 512
BS34 pilot jets
- baldy110
18 Jan 2012 22:48 - 18 Jan 2012 22:49 #498759
by baldy110
BS34 pilot jets was created by baldy110
I have a set of BS34's and I want to replace the pilot jets from 37.5 to a 40. I have a box full of pilot jets however they are the bleed type, little holes drilled on the sides. The ones I pulled out of the BS34 were not the bleed style, no little holes in the sides. Will the bleed type work? Thanks
Last edit: 18 Jan 2012 22:49 by baldy110.
- Motor Head
- Thank you received: 391
24 Jan 2012 01:40 #499745
by Motor Head
Replied by Motor Head on topic BS34 pilot jets
I've been running the 40 Bleed type in the 82 K2 BS34's with no problems. They are fine. Only a slight bit of difference from the non-bleed type.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
24 Jan 2012 15:31 - 24 Jan 2012 15:32 #499833
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic BS34 pilot jets
Changing up to a 40 (bleed type) will work fine, but why???
It isnt necessary - even with pods, and may make the bike a little sluggish off the line.
What is deffinately required is the proper needle taper - that can only be aquired from a jet kit... or maybe Sudco?
BS34 + Pods = Headaches and sacrifice of power in some spot in the throttle/rpm range.
... course you could have a pumped motor, and may require it...
Good luck!
Good luck!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 24 Jan 2012 15:32 by TeK9iNe.
- baldy110
24 Jan 2012 18:36 #499865
by baldy110
Replied by baldy110 on topic BS34 pilot jets
I have a modified engine, bigger bore, higher compression and head work.
