Proper petcock operation when starting
- SuperTrey
24 May 2006 17:42
Forgive me if this is a dumb question. I am new. My 1978 KZ1000A was given to me by the family of a friend who passed away, and the bike had now owner's manual.
The petcock has reserve, pri (for prime?) and on. What is considered off? and what is the appropriate way to start the bike? in the prime position then switch to on or start in on?
Thanks.
Thanks.
- KZ_Rage
- Kentucky Bourbon Barrel Ale
Re: Proper petcock operation when starting
24 May 2006 18:11
There is no off.
The PRI is for priming the carbs only if it has been sitting for a long time or you ran out of gas.
Leave it in the "ON" position. It uses vacuum to control the release of gas to the carbs. If the petcock is bad it will flood fuel into the carbs even when the bike is not running. You should check for this as it has sat for a long time now.
Post edited by: KZ_Rage, at: 2006/05/24 21:11
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
1984 KZ550F2 SOLD!
- rstnick
24 May 2006 18:13
Welcome.
Your petcock is a vacuum type, and has no off position. Gas will not flow in the ON or RES positions if the engine is NOT running. So if you want to remove your tank, put it in either of these two positions.
In the PRI (prime) pos., gas will flow freely.
When starting, I will usually move the petcock to Prime if the bike has been sitting a few days. This will fill the carbs. Then switch it to ON after a few moments. You can just leave it in the ON position if you have just rode her recently, or if you ride everyday. If you have trouble starting her, try switching to Prime.
After a while you'll get a feel for when you need to use the Prime pos.
Hey Rage, you slipped that in! :lol:
Post edited by: rstnick, at: 2006/05/24 21:14
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- SuperTrey
24 May 2006 20:32
Thanks! is there a source for buying copies of orginal Kawasaki owners manuals?
- wiredgeorge
25 May 2006 06:36
The KZ1000 Factory Service Manual is one of the very best Kawasaki manuals. It is FAR better than the Clymer manual for the same bike which covers 73-80 900 and 1000 models but the Clymer manual is OK and it does work well for a beginner mechanic because of its good pictures. A Haynes manual for the same range of bike manuals exists but it is written by a British person I think and a bit harder to decipher and the pictures are not great but would work in a pinch.
The best source for a Kaw service manual is eBay. They do come up for sale and there is a section for manuals in the parts section I think on eBay motors.
