- Thank you received: 3
28mm vs 26mm dimensions
- notaduc
13 Jan 2012 13:02 #497925
by notaduc
1980 (mostly) KZ1000
28mm vs 26mm dimensions was created by notaduc
I am looking for the dimensions of the filter side of the VM28, the inside and outside diameters of the bit that the airbox would clamp to.
If someone would be so kind, fairly accurate.
Or if they are the same as the 26, I can just measure mine...
Thanks!
Thanks!
- testarossa
- Thank you received: 82
13 Jan 2012 14:01 #497932
by testarossa
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
Replied by testarossa on topic 28mm vs 26mm dimensions
VM26,28,29 should all be the same.
2004 ZX-10R
Angola, IN
- Garn
- Thank you received: 13
13 Jan 2012 20:42 #497978
by Garn
1 x 73 Z1 (Jaffa), 74 Z1A, 76 Z900-A4
1 x 73 Yamaha TX500 & 98 fzx250 Zeal
Sydney Australia
Replied by Garn on topic 28mm vs 26mm dimensions
Agree with Terrarosa.
Regardz.
Regardz.
Sydney Australia
- notaduc
15 Jan 2012 18:41 - 15 Jan 2012 18:44 #498200
by notaduc
Replied by notaduc on topic 28mm vs 26mm dimensions
Ok, so I bought some 51mm oval K&N filters off amazon for $47 shipped. I wanted to adapt them to use with 28mm carbs, so I made these delrin adaptor sleeves/bellmouth.
They have a groove on the carb side ID so they snap in place very tight.
Last edit: 15 Jan 2012 18:44 by notaduc.
