are pod filters better than a box on csr 1000?
- New2Kz
if not my question is about my 81 csr 1000, i noticed tonight the intakes from airbox to carb are out of shape and warped from age, there not fitting to well on carbs, is it better to go with pod filters anyway? i was thinking of running them, and i assume i would need to re jet carb?
also tried firing up bike tonight after its sat for couple months, carbs are getting gas but not into cyclinder. Is there any other reason why this would happen other than dirty carb? i just thought at least one of them would get gas, i checked both outer cylinders threw plugs and both were dry, losened screw for carb bowl and gas was present in bowls, any ideas?
1981 kawasaki kz csr 1000( stock for now)
2001 gsxr 619 track bike
- DoubleDub
- Visitor
- New2Kz
any good threads i should look for?
- ramtough_63
It all boils down to your preference and application.
as for as your carb problem I am just learning so I am not the go to person on this but, I will throw this out there.
before condemming the carbs or assuming no gas is entering by way of plugs arent wet do some checking.
making sure you have spark etc..
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
- Thank you received: 2829
- Thank you received: 2098
Click > www.z1enterprises.com/detail.aspx?ID=411
In any event, don't damage or dispose of the stock air box. [You know why.]
- steell
- randomMX
- DoubleDub
- Visitor
- steell
cavanaughracing wrote: B34's & Pods.... is like Lactose intolerant & Milk :laugh:
- faffi
- Thank you received: 36
The main benefit for me with pods is that they make carbs much easier to remove and refit. But compared to simply having an engine that runs well and isn't bothered with strong winds and/or rain, it's usually a small inconvenience.
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
- New2Kz
thanks again for the help on a tired subject
