- Thank you received: 3
VM28 bottleneck
- notaduc
12 Jan 2012 00:16 #497651
by notaduc
1980 (mostly) KZ1000
VM28 bottleneck was created by notaduc
Typically do the 28mm carbs go well after head work? Im stock bore, 4-1 exhaust, street port/3 angle head, pods.
Im willing to upgrade carbs if they become the bottleneck...
Anyone have experience with a similar situation?
- DoubleDub
- Visitor
12 Jan 2012 00:56 #497661
by DoubleDub
Replied by DoubleDub on topic VM28 bottleneck
Whoever does the porting ought to know the flow numbers for the carbs and have them for the head when it's done.
- notaduc
13 Jan 2012 13:04 #497926
by notaduc
Replied by notaduc on topic VM28 bottleneck
I will happily swap carbs to match the head, just curious what the flow limits of the 28's are...
- DoubleDub
- Visitor
13 Jan 2012 13:57 #497930
by DoubleDub
Without porting, the head is likely the flow limiter.
- etbike3135
- Thank you received: 50
13 Jan 2012 13:57 #497931
by etbike3135
1973 Kawasaki Z1
18 years in dragbikes
Replied by etbike3135 on topic VM28 bottleneck
Your not doing cams or pistons? I would say your ok with the 28's on a budget build if your not doing cams and or pistons with it. A street port is usually just cleaning up around the valve bowl and not really opening up the ports any. Should be ok and a common thing if you just needed the head rebuilt anyway.
1973 Kawasaki Z1
- notaduc
13 Jan 2012 15:34 #497941
by notaduc
No cams or pistons. Just servicing the head, and figured id get the ports cleaned up a bit.
- LarryC
15 Jan 2012 21:56 #498224
by LarryC
Larry C.
Replied by LarryC on topic VM28 bottleneck
Run the 28's until you can afford a rack of performance carburetors. They'll be fine. Ported head or stock, a good rack of performance carbs makes a nice boost. Small motor...CRS29 makes a nice all around carburetor.
Larry C.
- mtkawboy
- Thank you received: 16
16 Jan 2012 15:21 #498331
by mtkawboy
Replied by mtkawboy on topic VM28 bottleneck
Do you have early or late Z1 carbs, late Z1R type w/accellerator pumps or 28 mm smoothbores ? The Z1R type are leaner then a popcorn fart from the factory
