Float Bowl Leak -- Gaskets?
- tbaumga2
08 Jan 2012 00:10 #497003
by tbaumga2
Float Bowl Leak -- Gaskets? was created by tbaumga2
On my 84 Gpz550, the left-most float bowl is leaking gas out of top of the bowl, where the top bolts on. (sorry for no pics, i've got it in storage at the moment).
Could this be a bad gasket? If so, does each bowl have its own gasket, or is there a single piece that covers all of the bowls? Where would one go to even get a new one?
Sorry for the n00b questions, just inherited the bike from my brother a few weeks ago.
- Thank you received: 2098
08 Jan 2012 00:26 #497009
by Patton
Replied by Patton on topic Float Bowl Leak -- Gaskets?
O'ring Part No. 92055-1128 shows still "active" at kawasaki.com which means it should be currently available through Kawasaki dealerships.
Lots of good info on kawasaki.com, including parts diagrams, part names, part numbers, models sharing same part, availability, etc. Here's a link for help with navigating the site and finding information.
kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
08 Jan 2012 00:28 #497010
by Patton
Carb rebuild kit is listed at Z1E.
Click > www.z1enterprises.com/Carburetor-Rebuild...ZX550-8285-2028.aspx
- boatdrinks
- Thank you received: 54
08 Jan 2012 11:09 #497048
by boatdrinks
Charles
Madison, AL
1978 KZ650 B2A, Luminous Dark Blue
Replied by boatdrinks on topic Float Bowl Leak -- Gaskets?
This may sound a bit simplistic, but have you tried tightening the screws?
Charles
Madison, AL
- Motor Head
- Thank you received: 391
08 Jan 2012 11:53 #497051
by Motor Head
Replied by Motor Head on topic Float Bowl Leak -- Gaskets?
If you think you just need new O-rings on the carb bowls, then here you go:
www.z1enterprises.com/Carb-Float-Bowl-Or...Z550-ZX550-2549.aspx
If you want rebuild kits Z1 will have those as well.
Either way make sure you get the fuel level in each carb set correctly, and I would clean out the jets and circuits while there. Remove the carb rack and do this all on the work bench.
A can of spray carb cleaner and an air compressor, some 12" sections of clear tubing to connect to the float bowl drain for the fuel level testing. Look for the procedure in your manual, or Patton has a great tutorial on it.
- tbaumga2
09 Jan 2012 13:05 #497229
by tbaumga2
Replied by tbaumga2 on topic Float Bowl Leak -- Gaskets?
thanks for all the great info guys! Ill start with tightening the screws and cleaning the jets before i get to replacing anything, never thought of that
