1980 kz750 carb interchange
04 Jan 2012 00:21 #496211 by The1stKZ
1980 kz750 carb interchange was created by The1stKZ
Hey all, I've been reading through the forums, but cannot find my answer. I have a 80 kz750 and 3 carb slides are frozen. Needless to say, I'm thinking I need some new ones. Now would a Mikuni 26mm from a 77 kz1000 work? I'm looking for something that is pretty much a bolt on. I'm not looking for performance upgrade or anything. I know the spacing is the same and they will physically fit, but they need to work too. Thanks for any and all help!
04 Jan 2012 00:41 #496215 by Nebr_Rex
Replied by Nebr_Rex on topic 1980 kz750 carb interchange
You will need new Carb boots for a 900/1000 and then elongate the holes.
Also push pull throttle cables.
Bike should run better once the jetting is figured out.
And they're pod friendly. ;)
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
