- Thank you received: 1
1978 KZ1000Mk11 Carbs
- mixstup
02 Jan 2012 22:14 #495927
by mixstup
Thornbury .Ont. Canada
1978 KZ1000Mk11 Carbs was created by mixstup
Hi Guys
I recently bought a non running barnfresh KZ1000 mk2 with a set of 29mm Mikunis fitted.I took them apart,washed them in the ultrasonic bath and was putting them back together when I discovered the number 4 carb had a 17.5 pilot instead of the 15s found in the rest.Is this normal? I have a Clymer manual and it alludes to the fact either are used but is not specific,I would have assumed they would be the same across all 4.The manual also says the carb size for this model is a 26mm Mikuni...any ideas would be very welcome...
it has a set of Taylor leads,4-1 pipe,Marzocci piggybacks.The plan is to see if it runs and then have a look inside the motor!
thanks
mick
thanks
mick
- donthekawguy
- Thank you received: 8
03 Jan 2012 00:42 #495963
by donthekawguy
What he said. the MK11 didn't come out till 79 with the 28's. Make sure you have what you have. Check the vin and go from there.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
Replied by donthekawguy on topic 1978 KZ1000Mk11 Carbs
arai wrote: MK 2's came with 28 pumpers stock. Which also was a 79 model. The 29's are a good fetch on that bike, congrats. The 29's are far easier to work on and perform well. I believe 26's were on stock 1000's in 77-78.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- mixstup
03 Jan 2012 20:45 #496150
by mixstup
Replied by mixstup on topic 1978 KZ1000Mk11 Carbs
Thanks guys,I'll check the vin and report back!
