hey how about another jetting question?
- lunchbox
23 May 2006 19:06
i'm putting a set of pods on my 81 kz 750, but i'd like to leave the stock 2into 1's on the bike. usually i'd upgrade the exhaust, jets, and airflow all at the same time, but i'd like to keep the exhaust. have any of you did this? if so how many jet sizes worked for you? i'm running stock keihin(sp?) carbs, 26mm cv's. and have any of you changed to hotter plugs when doing this? thanks in advance!
lunch
p.s. i did a search and didn't find the answer i was looking for.
Post edited by: lunchbox, at: 2006/05/23 22:12
lunch
- wiredgeorge
Re: hey how about another jetting question?
24 May 2006 06:47
By adding the pods, you are leaning your air/fuel mixture so the hotter plugs would be a real poor idea.
I don't remember the stock jetting on a KZ750... what is it? You have a main, secondary main and slow jet. Adding pods, I would likely try one size up on the main, three sizes on the secondary main and one size up on the slow jet but I doubt you will find the larger slow jets. Leave the jet needle alone at this point as the fat little Keihin jet needles seem to work OK without shimming.
- lunchbox
25 May 2006 15:25
you are a god! thanks alot, i was racking my brain trying to figure out a good starting point. now i just need some power to the headlight and i'm on the road! thanks again george!
lunch
lunch
- wiredgeorge
26 May 2006 07:36
I can assure you that there is only one God and I am not He! Hope the info helps...
