- Thank you received: 1
gas flow
- wcrider62
30 Dec 2011 12:40 #495284
by wcrider62
probablwe a dubm question but after months of hell with my bike I think I just had a brain movment. there are 2 vacume lines that go to my carb rail from the motor-- prabably dubm quastion but --would that happend to be mabye causing the probablem starting my bike?? eather I have to pull or -with help- push start that heavy thing was just thinkin those 2 hoses go to the fuel rail.well I hope it works , going to shed and give it a try
1982 kz1100 spectre D1
gas flow was created by wcrider62
Attachment newlook_2011-12-30.jpg not found
- Kawickrice
- Thank you received: 18
30 Dec 2011 16:36 #495318
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic gas flow
Some carbs have nipples that vent to atmosphere so you should really do your research before winging it. Is the bike fuel injected? you mentioned fuel rails.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Thank you received: 2829
30 Dec 2011 19:39 #495352
by 650ed
Right! It's time to buy the Kawasaki Service Manual. No KZ owner should be without one (or more than 1). Ed
Replied by 650ed on topic gas flow
Kawickrice wrote: Some carbs have nipples that vent to atmosphere so you should really do your research before winging it. Is the bike fuel injected? you mentioned fuel rails.
- Thank you received: 2098
30 Dec 2011 23:48 #495384
by Patton
Replied by Patton on topic gas flow
vent should be open to atmosphere
vac shouldn't be open to atmosphere.
- andy9802gt
- If it tastes that good, eat it yourself.
31 Dec 2011 07:26 #495420
by andy9802gt
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Replied by andy9802gt on topic gas flow
Post a picture of the carbs so we can see what you're talking about. They're probably not fuel lines if the bike runs when you push start it. What is the jetting on your carbs at the moment? Have you tried starting it with the choke on or the air filter/s off? Which kind of petcock do you have? Are you sure you're getting spark with the electric starter? Have you tried kicking it if you have a kicker?
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- wcrider62
01 Jan 2012 22:45 #495760
by wcrider62
ok lets see if I can remember all the questions, no its not fuel injected the petcock has a line coming from the engine to cause pressure to push the fuel down, on and reserve only flow when engine is running pri free flows. the lines I was talking about come fron a vacume modularot under the tank tward the front. and the boots to conect the carbs to the air box are gone. and there is no kick start . as for winging it. I dont have a choice dont know anyone here that works on bikes and cant realy afford to pay anyone. thanks to washongtons govenor and our $%^&(&^ press.
Replied by wcrider62 on topic gas flow
Attachment HPIM1763_2012-01-01.JPG not found
- wcrider62
01 Jan 2012 22:45 #495761
by wcrider62
Attachment HPIM1763_2012-01-01-2.JPG not found
- wcrider62
07 Jan 2012 21:11 #496964
by wcrider62
ok I redid the vacume lines to the carbs and my fuel flow problem is fixed . thanx for the help
