- Thank you received: 6
CV Rebuild Kit 'O' Rings
- mwriders
- if I only had a brain
28 Dec 2011 13:34 #494985
by mwriders
1980 Kawasaki KZ440B (brand new eBaby)
1998 Ducati 900S (gone)
1978 BMW R100S (gone, damn it)
1975 Yamaha RD350 cafe (gone)
1986 Yamaha XJ650 Seca (gone)
1981 Kawasaki KZ440LTD (gone)
1969 HD Sportster (gone
1966 Honda CB160 (gone, damn it)
1965 Suzuki 80
CV Rebuild Kit 'O' Rings was created by mwriders
So, here's a simple question. The attached picture is of a typical CV rebuild kit (Z1's version). The picture shows three 'O' rings of three sizes. For what specific application is each size ring intended?
1965 Suzuki 80
- JR
- Thank you received: 449
28 Dec 2011 22:36 #495052
by JR
Replied by JR on topic CV Rebuild Kit 'O' Rings
that rebuild kit is like the one I use on the CV34s on my 750/4.
One O ring goes with the metal washer on the end of the brass mixture screw. One goes on the end of the drain screw and one is for the plastic plug that covers my pilot jet. Offhand I cant remember which o ring goes on the mixture screw so I would suggest you check when you remove the screw. Once you pin that one down the other two will follow.
Good luck
Good luck
- P21
- Thank you received: 34
28 Dec 2011 22:42 #495053
by P21
Kawasaki KZ 1000 Police (2002) P21
Replied by P21 on topic CV Rebuild Kit 'O' Rings
i'll second the above
- mwriders
29 Dec 2011 11:20 #495124
by mwriders
1965 Suzuki 80
Replied by mwriders on topic CV Rebuild Kit 'O' Rings
My problem is that the carbs came in a box and were not complete. For instance, the plastic plug had been replaced by a screw inserted in a piece of plastic tubing. So, I can't follow the strategy of putting things back together the way they came apart. My question is which 'O' ring is designed for the plastic plug and which is intended for the pilot screw.
1965 Suzuki 80
- JR
29 Dec 2011 18:06 #495185
by JR
I am pretty sure - not totally - that the larger O ring is for the plug. May be a tight fit and may need to be shaved a bit but as to the other 2 I am just not sure at all. Surely there must be a drain screw or mixture screw in there with an O ring still on it for comparison ?
Sorry cant be more help.
- P21
29 Dec 2011 22:43 #495218
by P21
maybe this will help drawing are not real clear
www.bikebandit.com/houseofmotorcycles/19...-us/o/m3957#sch87004
