Carb drain screw ?
- mvent
Carb drain screw ?
27 Dec 2011 23:41
Removed float bowl drain screws on carbs to replace o rings and 1 was brass with hole down center and base of threads (happened to be the one that leaked) the other 3 were steel with no holes, which are correct? 78 1000 A2A
Thanks
Thanks
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
Re: Carb drain screw ?
28 Dec 2011 01:04 - 28 Dec 2011 01:08mvent wrote: Removed float bowl drain screws on carbs to replace o rings and 1 was brass with hole down center and base of threads (happened to be the one that leaked) the other 3 were steel with no holes, which are correct? 78 1000 A2A
Thanks
Stock drain screws on 1978 KZ1000-A don't have holes.
Last edit: 28 Dec 2011 01:08 by Patton.
- mvent
28 Dec 2011 10:31
Thanks Patton
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
