two to one carb
26 Dec 2011 07:21 #494690 by Beaker
two to one carb was created by Beaker
i have a 82 Kz750 180 degree engine im planning on flipping the number two cylinder 180 out the math works out as no way in hecks half acre ill sync the carbs and keep them in tune for this ,,,my plan is to build an intake and put one carb with honed out jets.Any oppinions. :whistle:
Beaker
26 Dec 2011 14:53 - 22 Jan 2013 00:41 #494733 by H1Vindicator
Replied by H1Vindicator on topic two to one carb
Last edit: 22 Jan 2013 00:41 by H1Vindicator.
26 Dec 2011 16:16 #494744 by Patton
Replied by Patton on topic two to one carb
26 Dec 2011 19:17 - 26 Dec 2011 19:17 #494759 by loudhvx
Replied by loudhvx on topic two to one carb
You want to make a 180 degree crank for the 750 twin? Why? The 360 crank motor already has the balancing hardware in it, and it's so much smoother than a 180 twin.
If you want to use a single carb, then you are much better off keeping it a 360 crank (as it is stock). You'll never get equal charge to both cylinders if it is a 180 crank with single carb.
Last edit: 26 Dec 2011 19:17 by loudhvx.
26 Dec 2011 19:33 #494760 by 650ed
Replied by 650ed on topic two to one carb
In a word......
26 Dec 2011 20:41 #494765 by Beaker
Replied by Beaker on topic two to one carb
Sorry I cant write to well thank yall for your input my reason for this is hourses after all you got two kinds of bikes.Ones with hourses ones with peddles.After im done ill post how it pans out .As for my weird creativity,I never look at things and ask why.I dream of the way they can be and ask why not?
Beaker
  • wireman
26 Dec 2011 21:06 #494767 by wireman
Replied by wireman on topic two to one carb
you were quite the roll model for me growing up!
Attachment beaker.jpg not found
:woohoo:
26 Dec 2011 21:07 #494768 by ramtough_63
Replied by ramtough_63 on topic two to one carb
i'm in! keep us posted send some pics as you go always love to see how these things turn out
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
26 Dec 2011 21:26 #494769 by 650ed
In a KZ750 4 stroke 360 degree twin the crankshaft throws are side by side and the pistons rise and fall together. The #1 cylinder fires and after the crankshaft has spun 360* the #2 cylinder fires. So as each cylinder fires the opposite cylinder is at the end of its exhaust stroke with its piston at the top of the cylinder. If you were to assume the position of the crankshaft to be at 0* when #1 fires it will be at 720* when #1 fires again; and #2 will fire at 360* and at 1080* when it fires again, etc. All power strokes of the 2 cylinders are spaced 360* apart making an even running engine that can be balanced fairly easily.
If the crankshaft is modified so the throws are 180* apart the cylinders will no longer fire 360* apart. Instead, if cylinder #1 fires at crankshaft position 0* #2 will fire at 180*. Then there will be a gap of 540* before #1 fires again and 180* latter #2 will fire. As a result, instead of the pulses being 360*/360*/360*/360* they will be 180*/540*/180*/540*. This makes trying to balance the engine rather difficult if not impossible. Harley has been struggling for years with very limited success trying to smooth out their engines because they are not phased 360* because their V-twin cylinders are spaced 45*.
The KZ750 twin has a separate balancer built in to help dampen vibration. This balancer is made to dampen pulses that are 360* apart. It will not work properly, and may in fact worsen vibration, if the pulses are set so the first pulse is 180* and the second pulse is 540* apart.
Because of the above issues, I believe you will not be able to successfully complete your project. Is it fair to ask what you believe the advantage of such a configuration will be? But despite my reasoning above, please don’t let my doubts discourage you as it will be interesting to see what challenges you encounter and how you address them. Ed
  • wireman
26 Dec 2011 21:32 #494770 by wireman
what about the cam shaft? B)
26 Dec 2011 21:36 #494771 by 650ed
wireman wrote: what about the cam shaft? B)
Just one (or two) more little problems to overcome. ;)
  • DoubleDub
  • Visitor
26 Dec 2011 21:46 #494772 by DoubleDub
Replied by DoubleDub on topic two to one carb
Boy, if only syncing the carbs were easier than all this.... :blink:
www.z1enterprises.com/Vacuum-Carb-Synchronizer-1689.aspx
