jetting for a Vance an hines exhaust 1977 kz 1000
- wdizard
24 Dec 2011 16:36 #494555
by wdizard
jetting for a Vance an hines exhaust 1977 kz 1000 was created by wdizard
I want to go from a stock exhaust to a vance and hines 4 into one exhaust. Does anyone know what kind of jetting that I will need to change? The engine is a 1075cc also, the carbs are stock with a stock airbox.
- gd4now
- Denco where did you go?
- Thank you received: 445
24 Dec 2011 17:01 #494556
by gd4now
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Replied by gd4now on topic jetting for a Vance an hines exhaust 1977 kz 1000
You may not need to make any jetting changes. Not all exhaust changes require jet changes. Changes to air intake are more likely to require jet changes.
1977 KZ650 B1
- dejavoodo41
- Thank you received: 14
24 Dec 2011 21:28 #494575
by dejavoodo41
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
Replied by dejavoodo41 on topic jetting for a Vance an hines exhaust 1977 kz 1000
When I was running vm26's with pods on my 1105 I believe I was running #20 pilots #120 mains with the needle on the 3rd clip to my best recolection. I'm at sea level near Daytona Beach. Hope this helps.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
24 Dec 2011 22:45 #494580
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic jetting for a Vance an hines exhaust 1977 kz 1000
If it ran fine before, it will likely run fine without any jetting adjustments - but for MAYBE a slight adjustment to the mixture/air screws.
Good luck.
Good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- mtkawboy
- Thank you received: 16
27 Dec 2011 20:26 #494880
by mtkawboy
Replied by mtkawboy on topic jetting for a Vance an hines exhaust 1977 kz 1000
The 76 KZ900 carb jetting specs are just about perfect for an air box pipe with a 4-1. Mains are 115, cant recall off hand what the pilots are. This is the combo that Superbike Mike in Ft Lauderdale Fl. used to build my KZ900 10.25-1 1105 wirh 395 lift 260/260 shim on top cams & a street ported head. It hauled butt in 1978 and still does
- donthekawguy
- Thank you received: 8
28 Dec 2011 00:32 #494904
by donthekawguy
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
Replied by donthekawguy on topic jetting for a Vance an hines exhaust 1977 kz 1000
Pu the pipe on and a new set of plugs and see what happens. I put on a kerker and it ran a little lean. Not enough for a jet change I just fattened it up a little and it's fine.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
