- Thank you received: 36
Corroded carbs
- mtbspeedfreak
2000 ZRX 1100
1976 KZ 900- Daily Driver
- DoubleDub
- Visitor
- KZJOE900
- Admin
Joe
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- DoubleDub
- Visitor
- 750steve
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
- mtbspeedfreak
I took the top caps and float bowls off last night, they are clean inside, I was surprised! It just looks like there is external corrosion.
Should I completely disassemble the carbs before boiling in the lemon juice solution? I was just going to dip the carbs in an old metal toolbox sitting on my propane grill outside to boil for a few hours.
2000 ZRX 1100
- mtbspeedfreak
Also, anyone have a single top cap screw, four float bowl screws and a float bowl they're willing to part with?
2000 ZRX 1100
- KZJOE900
- Admin
mtbspeedfreak wrote: These are what I'm working with:
You don't have to take them completely apart. You can at least leave them attached to the rack. But because of the rubber parts you will need to take most everything else off (accelerator shaft due to the the grommets, any diaphragms, floats, etc) off. Should take all the jets off to allow better flow of the solution and so forth. After the lemon juice/water cooing is done. You should still use carb cleaner through the passages (pilot circuit as per Patton's instructions and the choke circuit) and compressed air through the passages to finish it off. Mine had mud packs in some of the passages. And the boiling will not work on that as great as other debris. So the better you clean it the less chance for issues later on. Good luck.
Joe
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- DoubleDub
- Visitor
- TomW
- Keep the blue side up.
- Thank you received: 52
Also, anyone have a single top cap screw, four float bowl screws and a float bowl they're willing to part with?[/quote
I've got the screws. I replaced mine with SS Allen heads. Can't help with the bowl. PM me.
'78 KZ1000B2 LTD stock + Vetter Fairing & luggage
'91 ZG1200B5 Voyager XII, stock
- mtbspeedfreak
Thanks I have the screws taken care of, still looking for the float bowl. I'll post something in the "Wanted" section soon.
2000 ZRX 1100
- Kawboy74
Good luck David
1974 Z1A As original as I could get it
'88 ZX750R braided lines, mostly original
KZ1000 project on the bench
Burlington,Ontario,Canada
