OEM Jet Needle
  • bloglos
  • bloglos's Avatar Topic Author
OEM Jet Needle
10 Dec 2011 21:58
#492580
So I'm finally getting around to rebuilding a set of VM24's from a C2. I noticed the jet needle in carb one was bent pretty bad at the tip, so I looked up the OEM part number on Kawasaki's site and ordered one up.
Part number was: 16009-071
I get it in the mail and it looks good, but upon closer inspection it looks like it's a little thicker. Near the tapered tip especially. Also, the original bent one is stamped: 5CN15 and the newer one is stamped: 5DL31
Should this be a concern? Picture attached.
Attachment IMG_0882.jpg not found
78 KZ650 C2 - Runner
77 KZ650 B1 - Project
  • bountyhunter
  • bountyhunter's Avatar
Re: OEM Jet Needle
10 Dec 2011 22:52
#492583
Probably the closest replacement needle available. The ones in my rebuild kit were WAY off from the stock needle.
  • bloglos
Re: OEM Jet Needle
10 Dec 2011 22:58
#492584
I suppose it's better than the ridiculously bent needle I was running.
bountyhunter wrote: Probably the closest replacement needle available. The ones in my rebuild kit were WAY off from the stock needle.
  • Motor Head
  • Motor Head's Avatar
Re: OEM Jet Needle
10 Dec 2011 23:03
#492585
You need to order the correct needle. That replacement one is to lean for your set up. Otherwise you would have to buy more needles and needle jets, etc to make all carbs the same. Look here:
  • bloglos
Re: OEM Jet Needle
11 Dec 2011 00:24
#492600
Motorhead, what site is that? I only ordered on thinking it was correct.
  • Motor Head
Re: OEM Jet Needle
11 Dec 2011 00:42 - 11 Dec 2011 00:43
#492603
It is just the Kawasaki Parts fiche, but at cyclepartsnation.com as it it easy to use. But as you can see there are a couple of different needles, get the same )# as you took out, all carbs need to be the same.
Ask Z1 they will have a better price I bet.
Last edit: 11 Dec 2011 00:43 by Motor Head.
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
Re: OEM Jet Needle
11 Dec 2011 04:37
#492623
First, yes you want all of the needles to match otherwise you will have issues attempting to get them to sync correctly. Not sure if you can still get the 5CN14 needle any more. But at the same time not sure how the 5DL3 needles will work with the needle jet in the carb. Either way in IMO all of the needles need to match, as do all of the needle jets.
Second, not all of the C2s came with the same carbs. From the info I can find there were 3 different carb assemblies used on this model. They are 16001-1022, 16001-1069, and 16001-1084. The needles in the 1022 set was the 5DL3-4 (part#16009-071)and the needle jets were O-8(that is an OH no a zero), in the 1069 set it was 5CN15-4 (part#16009-1013) and the needel jet was the O-4 and in the 1084 set the needel was 5CL16-3 (part#16009-1029)and the needle jet was AO-5).
The part # for the carb assembly should be stamped on the flange just below the choke lever. It will be something like this.
102
2(some other letter or number)
106
9(some other letter or number)
108
4(some other letter or number)
Just for additional info regarding the Mikuni needles and needle jets as I understand them
The needle jet is the main fuel passage to the main bore (venturi) of the carburetor. Depending on the inside diameter of a specific needle jet, this will also effect the function of the needle. therefore, needle jets and jet needles act togeher as the main system in controlling the amount and mixture of the fuel which is drawn in mid-range (1/4 - 3/4) throttle operation.
Needle jets are available not only in types, but by series and size. Mikuni series numbers for style of the needle jet. This series includes not only the physical fitment dimensions but also the nozzle profile, and the atomization pattern. The sizes (inside diameter size) within each series are listed according to a letter-number combination. The letter shows the inside diameter size in increments of .50mm. See the Mikuni Needle Jet Sizing Chart below for a better understanding
Mikuni Needle Jet Orifice Diameters in mm
-0 -1 -2 -3 -4 -5 -6 -7 -8 -9
N 2.550 2.555 2.560 2.565 2.570 2.575 2.580 2.585 2.590 2.595
O 2.600 2.605 2.610 2.615 2.620 2.625 2.630 2.635 2.640 2.645
P 2.650 2.655 2.660 2.665 2.670 2.675 2.680 2.685 2.690 2.695
Q 2.700 2.705 2.710 2.715 2.720 2.725 2.730 2.735 2.740 2.745
R 2.750 2.755 2.760 2.765 2.770 2.775 2.780 2.785 2.790 2.795
S 2.800 2.805 2.810 2.815 2.820 2.825 2.830 2.835 2.840 2.845
Y 3.100 3.105 3.110 3.115 3.120 3.125 3.130 3.135 3.140 3.145
Z 3.150 3.155 3.160 3.165 3.170 3.175 3.180 3.185 3.190 3.195
AA 3.200 3.205 3.210 3.215 3.220 3.225 3.230 3.235 3.240 3.245
BB 3.250 3.255 3.260 3.265 3.270 3.275 3.280 3.285 3.290 3.295
CC 3.300 3.305 3.310 3.315 3.320 3.325 3.330 3.335 3.340 3.345
The way Mikuni Needle numberings work is:
The first number is the length series. Lets take the series 4 needle. It could be 40.00-49.99mm in length. In turn a 5 could be 50.00-59.99mm in length.
The second and sometimes third characters being letters describe the taper from the clip end to the tip in 15minute (1/4th of a degree) increments. For example "B" is 30 seconds, and "E" is 1 degree, 15 seconds. Therefore a "BE" would be a taper starting out at 30 seconds (1/2 degree), followed by a second taper of 1min 15sec.
The last digit be it one or two characters is the suffix or revision number. Example. 4D3, and 4D8 are the same style needle, similar in length and taper. However the taper may begin higher up on the needle than the other. This would make a smaller tip diameter, or a shorter needle. If shims, or clip positions were incorporated on one needle it is possible that it may effectively perform like the other. For this reason we sometimes suggest ordering a 4D3, or 4D8 for example if an OEM application calls for a 4D5 which is not available, instead of a 4E?
Lastly there is sometimes a number designated by OEM's and this designates the clip position. Example: 5DP3-4. However this "-#" designation is not part of the needed part number.
One last note: A suffix number has the following unknown variables between one needle and another. Exact length, Major OD, Point of begining of taper in reference to clip position. Without physically measuring them there is no way to determine these characteristics just by looking at the part number.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Re: OEM Jet Needle
11 Dec 2011 11:10
#492639
Might be able to straighten the bent needle and return it to serviceable condition.
Could inquire at Sudco about availability of the correct jet needle:
Sudco International, 2410 South Sequoia Drive, Compton, CA 90220
New Phone (01) 310 637 8330 • New Fax 310 637 8331
Good Fortune! :)
  • P21
  • P21's Avatar
Re: OEM Jet Needle
11 Dec 2011 11:25 - 11 Dec 2011 11:27
#492642
do you have any means of measuring (mic) (calipers)
i would check where the yellow marks are an see if they are same?
Kawasaki KZ 1000 Police (2002) P21
Last edit: 11 Dec 2011 11:27 by P21.
