- Thank you received: 2
fresh built kz750 4 carbs??
- bearshawk
06 Dec 2011 22:34 #491959
by bearshawk
1978 kz650 sr- long time project/first bike mostly gone
1979 kz659 sr- new acquisition NEXT project GONE
Both 650s combined to make one great bike! with a new powerplant
it is a 79 frame, 78 front end, both 78 wheels and brakes, 78 body work and a 80' 750-4 motor with gpz 750 cams and a kerker and...
fresh built kz750 4 carbs?? was created by bearshawk
hey all, i have what i believe are VM24's accel pump versioin
the bike is a 750-4 in a SR650 frame with kerker, pods, and GPZ cams
i am wondering if i would benefit from different carbs like 26's or even 28's i have a long winter ahead of me and i want to make this bike run as smoothly as possible, i feel like shes a bit lean right now with 115 mains and 17.5 pilots but i ran out of riding weather before i got much tuning in.
the bike runs ok now but i bog down in the early RPMS and it hesitates a bit, i also have an occasional backfire through the carbs.
any help or advice on this subject would be great.
Thanks,
Ian
Thanks,
Ian
- clutch
- I wish I had a tad more patience to do it better!
- Thank you received: 12
07 Dec 2011 03:20 #491995
by clutch
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I...
Replied by clutch on topic fresh built kz750 4 carbs??
Not sure which model your motor is out of, but my 750 E has cv34's (maybe cv 32's...can't remember for sure). VM24 sounds really small to me, but I'm not sure what the ltd, and spectre motors came with
Wish List:
Z1 (need I...
- steve.w
07 Dec 2011 03:27 #491996
by steve.w
Replied by steve.w on topic fresh built kz750 4 carbs??
fit a dyno-jet stage 3 kit .. which will sort it ... :woohoo:
- bearshawk
07 Dec 2011 18:30 #492060
by bearshawk
Replied by bearshawk on topic fresh built kz750 4 carbs??
Well you see, the 750 motor is a E motor and its in my 650 frame...it should have had CV's on there before but i like the manual slide carbs better, it is far off stock jetting right now.. and im just wondering if there are any BETTER carbs for this application. hopefully the VM series
Thanks for the responses though
- DoubleDub
- Visitor
07 Dec 2011 19:16 #492064
by DoubleDub
Replied by DoubleDub on topic fresh built kz750 4 carbs??
I have seen people say the 26mm can make a big difference, properly tuned any of them should work. The bigger carbs will give you more power on the top end when you are flowing more air, afaik.
- bearshawk
07 Dec 2011 23:22 #492119
by bearshawk
ok cool, thanks for the heads up, i might go after a set of 26's then, my 24's need a rebuild anyway so if i get a new set i can just rebuild them this winter
