- Thank you received: 1
lost!!!!!!!!!!!!!!
- wcrider62
Attachment newlook_2011-12-03.jpg not found
1982 kz 1100 d1 .ok , I got spark , I got fuel. I swithed the spark plug wires around and she pops out the pipes and the carbs. I ride it here, shut it off, replaced starter ,replaced carb holders. now wont start . I got a heater beside motor now hoping heating the motor will help. last winter I had no trouble starting. I aint as young any more so pushing almost 800 pounds by my self with out a hill just aint working. before adding starter with help it would push start and then start easy and run great. I just dont know what to try next. Its my only transpo and I need her up and running. got doc appt. to make . any one got any ideas ????????????????
1982 kz1100 spectre D1
- ready2ryde1985
- got to love these kzs
- Thank you received: 4
check fuel
I am asuming the bike turns over ?
Check that the plug wires went back on the corect plug.
84 kz 700 a1
82 kz550 ltd
- wcrider62
- Thank you received: 2098
wcrider62 wrote: all back where they have been since I bought it.thwe poping stoped but still not starting. woundering if wally world sold me the right battery. I think I'll try jumping it with trhe truck tomorrow
Be certain that the truck motor isn't running, and that the truck ignition switch is OFF, and that the truck keys are in your pocket, all before connecting the jumper cables and any time the jumper cables remain connected.
- gumby prichard
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- gumby prichard
when doing the carb clean, submerge floats in water make sure there are no leaks, check your float needles and make sure they are in good condition also check float levels, there should be a line on your floats that will be parallel to the seam where the float bowl meets the carb base. (at least that's how it is on my kz400.)
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- Motor Head
- Thank you received: 391
- wcrider62
- wcrider62
- Motor Head
- wcrider62
