I've done a search but havent found anything so i need to ask the question.
As mt ignition will be operated either keylessly or with a different key i wondered if you guys had ant decent alternative fuel caps, it can be sxrew in or the push springy type. It'll probably have to be a kind of diamond shape though to tie in with the original shape & the indent in the top of the tank.
Incidentally, can only the actual cap bit be removed by pushing out the retainer pin? Thats the only bit that i seemwd to be able to remove.
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
