Carburetor set-up...Does this look right?
- mike_eubank
The vaccuum inlets are set up as such:
Carbs 1 and 4 are tied to each otherin a wish-bone set-up and run under the fuel tank. (Not sure to what)
Carb 2 is tied to the petcock to operate the diaphram in the fuel valve.
Carb 3 was open, which was of my slow idle and strange poppin,. I jury-rigged a cap using a piece of fuel line and slightly bigger cap.
My bike is stalling after a few minutes at highway speed. Capping the no 3 inlet helped, but it didnt solve the problem.
Im not an expert mechanic by any means; much less on motorcycles, but I can only think of two solutions:
1: The fuel diapraghm in the petcock needs BOTH carbs 2 and 3 to operate fully
2: The in-line filter in the main fuel line is visbily kinked (not by me) and is restricting fuel flow.
If at first you dont succeed, skydiving is NOT for you.
- cfaherty
You can rule out the petcock diaphragm by running in PRIME position and seeing if the problem goes away. PRIME is always flowing, whereas ON requires the vacuum.
1983 KZ750 F1 LTD Shaft
- Motor Head
- Thank you received: 391
- mike_eubank
- Motor Head
- mike_eubank
Ill try that. The fuel filter is kinked on one end (why, i dont know), so Ill check the flow rate like you said.
Thanks
- Motor Head
- Thank you received: 2829
- Motor Head
650ed wrote: All carbs are not the same. What carbs are you using? Ed
1980 KZ750 H1, Doesn't look to have the Inlet Screens or replaceable Seats on the Float Needles. Keihen CV Carbs.
- Motor Head
650ed wrote: Shouldn't a couple tubes go from thre carbs to the airbox? Ed
That would be the Bowl Vents. I believe your right he should have TEE fittings between two carbs up high near the rear, with those TEE's having hoses going to the Airbox. That's if it is still stock? Otherwise they would just route down, and hang near the sing arm pivot, along with the drain tubes, and battery vent.
If the bowl vent are plugged off, then fuel won't enter properly, causing starvation.
Good Catch 650ed!
Well the more I look at it I think his bowl vents are through the drain on the bottom. There would be a brass tube inside the bowl reaching above fuel level as a vent, and an overflow circuit. Here the only TEE is 23, and that is the Fuel Tube TEE.
- JR
- Thank you received: 448
I used to use clear line which would harden and kink. I would get about 3 or 4 miles down the road and then splutter splutter. Patton has a good diagram explaining how to get rid of that smog tubing which we never had up here and putting vacuum caps on the 1, 3 and 4 nipples.
The carb nipples in the diagram need to ne either connected to the petcock, connected to the smog tubing which is connected to the valve cover, or capped off.
Good luck - might be worth taking the gas tank off, checking the smog tubing, checking the petocok and putting on some good fuel line with no kinks,
