straight pipes
25 Nov 2011 10:48 #490085 by SCHWACKS
straight pipes was created by SCHWACKS
i have a 79 kz650. im running my pipes straight into one. does anyone have an idea on what size jets i should use?
25 Nov 2011 13:55 #490097 by steve.w
Replied by steve.w on topic straight pipes
what type of exhaust u fitted .. a lot of 4 into 1s ie harris etc dont require re-jetting ..
25 Nov 2011 14:11 #490098 by Mcdroid
Replied by Mcdroid on topic straight pipes
What alterations have been done to the air filter assembly?
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
26 Nov 2011 06:15 #490185 by bountyhunter
Replied by bountyhunter on topic straight pipes
SCHWACKS wrote: i have a 79 kz650. im running my pipes straight into one. does anyone have an idea on what size jets i should use?
One what?
02 Dec 2011 10:15 #491078 by SCHWACKS
Replied by SCHWACKS on topic straight pipes
thanks. gonna run the stock pipes, (4) and weld on a pipe so it goes into one pipe? am i wording that right? i did a rebuild kit on all carbs and put in 102.5 jets? I dont even have the motor in the bike yet!
02 Dec 2011 16:55 - 02 Dec 2011 16:56 #491134 by bountyhunter
SCHWACKS wrote: thanks. gonna run the stock pipes, (4) and weld on a pipe so it goes into one pipe? am i wording that right? i did a rebuild kit on all carbs and put in 102.5 jets? I dont even have the motor in the bike yet!
I don't know what jets to recommend. I know you will spend a ton of time trying to get it to run and it will never match the needle taper. Straight pipes never run right over the full range.
Last edit: 02 Dec 2011 16:56 by bountyhunter.
