Vacuum Leak
  • KZ7hundy
  • KZ7hundy's Avatar Topic Author
  • 1984 KZ700
Vacuum Leak
24 Nov 2011 19:48
#490041
So I just replaced a leaking carb boot with a brand new boot made for my model bike and i just checked it with the starter fluid test to see if the idle changed and it did. I don't know why it would not be air tight with a brand new boot on there. Is it normal for there to be a small change in the idle when that test is ran?
  • gengomerpyle
  • gengomerpyle's Avatar
Re: Vacuum Leak
24 Nov 2011 19:53
#490043
when i replaced my boots i used sealant to seal the head to the boot. i bought the gold colored sealant in a tube.
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
  • P21
  • P21's Avatar
Re: Vacuum Leak
24 Nov 2011 22:02
#490054
when you spray it be more precise with it just dont soak the shit out of it.
that way you can find where she is leaking at
and buy the way is that 700 a 4 or twin
Kawasaki KZ 1000 Police (2002) P21
  • P21
  • P21's Avatar
Re: Vacuum Leak
24 Nov 2011 22:04
#490055
if its not popped back in boot right it leak
Re: Vacuum Leak
25 Nov 2011 00:43 - 25 Nov 2011 01:13
#490060
KZ7hundy wrote: So I just replaced a leaking carb boot with a brand new boot made for my model bike and i just checked it with the starter fluid test to see if the idle changed and it did. I don't know why it would not be air tight with a brand new boot on there. Is it normal for there to be a small change in the idle when that test is ran?
Are the carbs pushed completely into the holders?
Are the clamps (that hold the carbs in the holders) correctly positioned, and sufficiently tightened?
Stock holders and stock carbs, so the holders are the correct size and not too large for the particular carbs being fitted?
If starter fluid is being ingested from the outside, then air is also being ingested from the outside (meaning an unwanted air leak).
There should be no need to apply any sealant of any kind, either between the holder and engine head, or where the carb fits into the holder.
It's okay to spray some WD40 or smear a little silicone lube (not sealant) or Armoral inside the holder before pushing the carb into the holder.
With the lube, the carbs are more easily fitted into the holders.
Good Fortune! :)
Last edit: 25 Nov 2011 01:13 by Patton.
  • KZ7hundy
  • 1984 KZ700
Re: Vacuum Leak
25 Nov 2011 01:04
#490063
It's a four. Thanks for the tips
  • P21
  • P21's Avatar
Re: Vacuum Leak
25 Nov 2011 13:26
#490095
can i ask did you replace ALL 4 boots?
i dont mean to be a smart azz but you go to all that trouble to remove carbs and such
then ONLY replace ONE boot thats like doing the job half azzed man.
ok now you can call me all the names you want.........lol
but really think about it
have a great day and good luck
